Samsung's Galaxy S26 FE is a decent phone, but it makes too many compromises to be worth your money
Not a flagship, but the price makes you think twice.
The Samsung Galaxy S26 FE in the Pistachio colorway on a bench.
(Image credit: © Brady Snyder / Android Central)
Android Central Verdict
The Samsung Galaxy S26 FE carves out a niche with its 6.7-inch display and $700 price point, but it's not the best value. With drawbacks limiting the screen and camera system, you might be better off choosing a cheaper midranger or seeking out a discounted flagship instead. However, with a flagship chip and One UI 9 out of the box, the Galaxy S26 FE certainly has its perks.
Reasons to buy
    Samsung's Exynos 2500 chipset is decent
    6.7-inch display is larger than most midrangers
    One UI 9 and Android 17, plus seven years of OS upgrades
    Relatively thin and light
Reasons to avoid
    Screen lacks uniform bezels and high peak brightness levels
    Rear camera system is weak outside of the 50MP primary shooter
    Slow 15W wireless charging; no Qi2 magnets
    Starts at 128GB storage
To get the cheapest Samsung or Google flagship in 2026, you'll need to choose a smaller phone. The Samsung Galaxy S26, for instance, is a 6.3-inch smartphone. If you want to splurge for a 6.7-inch display, you'll need to pay $1,200 for the Galaxy S26 Plus. That's $200 more than than the Galaxy S25 Plus went for, and $100 more than the Galaxy S26 Plus originally cost when it launched in March.
Phones with large screens are expensive, in other words — but the Samsung Galaxy S26 FE is an outlier. It offers the same 6.7-inch screen size as the Galaxy S26 Plus for $500 less, and it's worth your attention for that reason alone. I've used the Galaxy S26 FE for weeks, and it's closer to flagship territory than you may think.
But it also makes a handful of cost-cutting measures to hit that attractive $700 price point, and other phones provide a better value.
The price hike is hard to ignore
The Samsung Galaxy S26 FE in the Pistachio colorway.
(Image credit: Brady Snyder / Android Central)
Samsung's "Fan Edition" phones have always been in a tough spot in terms your wallet will understand. They're typically priced well above Google's midrange A-series models, as well as Samsung's own A-series phones. They're cheaper than Galaxy S series phones, but not by a whole lot. Further complicating matters is that the Galaxy FE phones have a screen size matching the Plus model of the Galaxy S lineup, making them attractive to people who want a larger display.
This year, the Galaxy S26 FE ships with a $50 price hike. That might not raise alarm bells considering the rising prices around the industry, but it should. The Google Pixel 11 and Samsung Galaxy S26 each saw a $100 price increase this year, and buyers get double the base storage in exchange. The Galaxy S26 FE, by comparison, still comes with the same 128GB of storage as standard.
If you want to match the 256GB storage of the rest of the Galaxy S26 series, get ready to pay $100 more for a Galaxy S26 FE. The 128GB model costs $699.99 and the 256GB version costs $799.99. This creates a puzzling lineup where the midrange Galaxy S26 FE and the flagship Galaxy S26 both launched at the exact same price, provided you got 256GB of storage for both.
Samsung retroactively raised Galaxy S26 and Galaxy S26 Plus prices, and the base model now costs $999.99. That does give the Galaxy S26 FE a better value proposition, but only slightly.
I'm starting off with pricing because it's the most important thing about the Galaxy S26 FE. As you'll learn throughout this review, Samsung's new midranger is as solid as ever, and it beats the Galaxy S25 FE in performance. However, it has the base Galaxy S26 and cheaper Android midrangers like the Google Pixel 10a and the OnePlus 13R breathing down its neck.
Swipe to scroll horizontally
Samsung Galaxy S26 FE specs
Category
Galaxy S26 FE
Processor
Samsung Exynos 2500
Memory
8GB RAM
Operating System
One UI 9, Android 17
Display
6.7-inch AMOLED, 120Hz, 1,900 nits peak brightness
Battery
4,900mAh
Charging
45W wired, 15W wireless
Dimensions
161.6 x 76.9 x 7.4 mm
Weight
193g
Rear cameras
50MP wide, 8MP telephoto, 12MP ultrawide
Front camera
12MP wide
The Galaxy S26 FE is a plus-sized midranger
From a design perspective, the Galaxy S26 FE shares a few similarities with the Galaxy S26 Plus; it's only a millimeter thicker and three grams heavier. Due to the larger bezels, the Galaxy S26 FE has a bigger overall footprint. Reachability is a bit of an issue due to the form factor, as it's both wider and taller than the Galaxy S26 Plus.
On the back, the key difference is the glossy Gorilla Glass Victus Plus. I prefer the matte look and feel of the Galaxy S26 Plus back, and that phone has newer Gorilla Glass Victus 2. But the colors for the Galaxy S26 FE are gorgeous. I reviewed the subtle Pistachio model, but you can also get the phone in Blueberry or Graphite colorways.
The Galaxy S26 FE uses a mix of glass and aluminum for materials, and it's IP68 certified against dust and water ingress. I had no problems with durability, and you shouldn't either. The device feels more premium compared to midrange phones with plastic backs, like the Pixel 10a.
The Galaxy S26 FE finds a niche thanks to its 6.7-inch display. It's the same size as the one on the Galaxy S26 Plus, albeit with a lower 1080p resolution. The screen isn't perfect — it has larger bezels, and more importantly, they aren't uniform. The Galaxy S26 FE has a "chin," and the lack of a consistent bezel size is unsightly to my eyes.
The chin has long been a sign you're looking at a Samsung budget or midrange phone compared to a flagship, and I think Samsung could've changed this by now. Google's midrange phone, the Pixel 10a, is cheaper and has uniform bezels.
Bezel talk aside, the Galaxy S26 FE isn't nearly as bright as its flagship counterparts. The phone has a peak brightness of 1,900 nits, whereas the Galaxy S26 and Galaxy S26 Plus top out at 2,600 nits. In practice, this means the Galaxy S26 FE won't be as easy to see outdoors. Without an anti-reflective coating, something becoming more popular on flagships, this phone is tricky to view in direct sunlight.
Otherwise, the display feels responsive with a 120Hz refresh rate. It's a fine panel for the price, even if there is clear room for improvement here. This is the exact same display we saw on the Galaxy S25 FE, and the Galaxy S24 FE for that matter. If you have one of these older phones, the Galaxy S26 FE's screen isn't a reason to upgrade.
A fresh chip, but the same slow charging
Samsung's midrange phones have come a long way in a few short years in terms of performance. As a refresher, the Galaxy S24 FE had an Exynos 2400e chip and the Galaxy S25 FE got the boost to the regular Exynos 2400 chip. This year, the Galaxy S26 FE runs on the Exynos 2500. It's a mobile processor built on a 3nm process (a major improvement over the 4nm Exynos 2400) that recently powered flagships like the Galaxy Z Flip 7 worldwide.
I tested the Galaxy Z Flip 7 firsthand, so I expected the Galaxy S26 FE to be a strong performer. I didn't expect for Samsung to pull so much extra power out of the Exynos 2500 for the Galaxy S26 FE. In the benchmark results below, you'll see the Galaxy S26 FE not only handily beat the Galaxy Z Flip 7, but also crush Google's Tensor G4-powered Pixel 10a.
Samsung Galaxy S26 FE benchmark results
Header Cell - Column 0
Geekbench 6 (single-core / multi-core)
Geekbench AI (quantized score)
3DMark Wild Life Extreme (score / fps)
Samsung Galaxy S26 FE (Exynos 2500)
2,362 / 7,848
4,643
5,253 / 31.46
Samsung Galaxy Z Flip 7 (Exynos 2500)
1,849 / 6,822
3,581
4,400 / 26.35
Google Pixel 10a (Tensor G4)
1,707 / 4,512
3,109
2,667 / 15.97
I'm surprised that Samsung is doing that with only 8GB memory onboard the Galaxy S26 FE. The Galaxy S26 FE ships with Android 17 and will get seven years of full Android OS support. Despite the RAM limitations, this phone will be a strong performer for a very long time.
The battery life is rock solid, too. It has the same 4,900mAh capacity as the Galaxy S26 Plus, but the Galaxy S26 FE's lower-resolution display and weaker chip combine to hep you squeeze a longer runtime out of it. The charging, unfortunately, is still too slow. The 45W wired speeds are fine, but 15W wireless charging is disappointing when the Qi2.2 25W standard exists.
It's worth revisiting the storage options. The Galaxy S26 FE ships with 128GB of storage by default, and you can upgrade it to 256GB or 512GB at the time of purchase. I think 128GB of storage is starting to stretch users thin because of growing app and operating system sizes. But if you upgrade the Galaxy S26 FE to 256GB or 512GB storage, you end up paying flagship prices for a midrange phone.
It's quite the dilemma, and one Samsung could've avoided by making 256GB standard, like the Galaxy S26 series. If you're fine with a 128GB phone, the Galaxy A57 is lurking in the corner at $599.99, but it does come with additional compromises.
The cameras are underwhelming for the price
Samsung isn't one to upgrade its phone cameras often, and the Galaxy S26 FE is no exception. It's using the same 50MP primary shooter, 8MP telephoto, and 12MP ultrawide lens we've seen on prior generations of Galaxy FE phones. The selfie camera is a 12MP, f/2.2 lens.
The telephoto only goes up to 3x optical zoom, but you may find digital zoom to produce passable results beyond that. Here's how the Galaxy S26 FE telephoto camera looks at 2x, 3x, and 10x zoom:
As for the main camera and ultrawide, it's a mixed bag. The 50MP sensor at the heart of the Galaxy S26 FE's rear camera system packs enough detail, and low-light performance is impressive. The photo of the "Aloha" sign in the gallery of camera samples below is as good of a night shot as I've taken recently. And for context, I've been using phones like the iPhone 18 Pro, Google Pixel 11, and Samsung Galaxy Z Fold 8 Ultra.
However, the phone's color science in daylight shots leaves a lot to be desired. Often, there's one part of the image that's brighter and color-saturated, by the overall scene is dark. The beach shots in particular stand out as looking darker as captured by the Galaxy S26 FE than the setting looked in real life.
I don't think the Galaxy S26 FE camera system is terrible, but I do think budget phones like the Pixel 10a and iPhone 17e will produce more desirable photos.
Should you buy the Samsung Galaxy S26 FE?
The Galaxy S26 FE only looks competitive on the surface of a smartphone market riddled with price hikes over the past year. Samsung's new $1,000 and $1,200 prices for the Galaxy S26 and Galaxy S26 Plus, respectively, make the Galaxy S26 FE at $700 seem like a discount. I want to emphasize that the Galaxy S26 FE is a great phone that I could absolutely use as my daily driver, despite its compromises.
That said, I still think you can do better. For example, last year's Galaxy S25 is available at the same $700 price as the Galaxy S26 FE at Target and Amazon. It has a smaller screen and battery, but it's a bona-fide flagship with a better camera and chip. If you're willing to compromise on screen size but want a cheaper phone, Google's Pixel 10a stands out. But it just got a price hike as well, and it's only $100 cheaper than the Galaxy S26 FE.
Looking at the Galaxy S26 FE in isolation, it's a solid phone. With OnePlus on its way out in the U.S., the Galaxy S26 FE represents one of your only options to get a plus-sized Android midranger. If it's important that you get a 6.7-inch Android phone for under a grand, I can recommend the Galaxy S26 FE — just be aware of the drawbacks, and consider your other options.
Brady Snyder
Contributor
Brady is a former contributor for Android Central, who wrote for the site from 2023 to 2026. With a focus on news, phones, and audio, he spent years reporting and commenting on all things related to consumer technology.
Brady reviewed Apple, Google, Samsung, and Motorola phones for Android Central, and attended industry-wide events like IFA and MWC on behalf of the publication. He holds a bachelor's degree in journalism from St. John's University.
His work has been published in XDA, Android Police, Android Authority, MakeUseOf, and SoundGuys, among other sites. When he isn't experimenting with the latest tech, you can find Brady running or watching Big East basketball.
