Protecting your LG V10 from wear and tear is a smart move and the perfect case can always be removed if you want that original look and feel.
Shopping for the right case to shield your LG V10? There certainly aren't as many options to choose from as we'd like to see, but there are still some great quality cases to consider if you're after the extra protection. These top 5 cases for LG V10 include slimmer selects that add just enough grip and impact control, along with some dual-layer hybrids that are built for serious situations.
Note: A known issue with many LG V10 cases available is the functionality of the fingerprint scanner. LG is working to improve the recognition of their scanner, but for best results we recommend programming this feature after your new case is installed.
Ringke Fusion Case
Crafted for those that prefer transparent protection to still show off their LG V10's design, Ringke's Fusion Case is a safe bet. This slim see-through cover features a smooth polycarbonate shell on the back that's surrounded by a TPU bumper. The combination of both materials do a pretty decent job of enhancing grip while the case is worn and manage to leave access to all the features of the LG V10. Included with the Ringke Fusion Case is an HD screen protector and a DIY template for creating your own custom designs.
See at Amazon
Spigen Slim Armor
Spigen's Slim Armor Case is built with a protective dual-layer design that doesn't overdo it on the bulk, adding a convenient, albeit flimsy kickstand on the back for landscape viewing. The inner TPU layer of the Slim Armor Case features Spigen's Air Cushion Technology on all 4 corners that do a lot for impacts when they occur. The smooth polycarbonate shell that sits on top leaves room for all the LG V10's camera features, but you may want to setup your fingerprint scanner again while the case is on if you plan to make this cover your daily driver.
See at Amazon
Caseformers Armor Case
This durable hybrid cover from Caseformers is choice for a rugged look, amazing protection, and even better grip. Although similar to the basic structure of the Slim Armor, the Caseformers Armor Case has a lot more going on with its exterior design — mixing up both TPU and textured polycarbonate layers for an easy hold. The kickstand that's been built into the back shell is a nice touch as it folds flush when not in use. This case's unique look may not be everyone's cup of tea, but it does come in 5 additional colors outside of the basic gray.
See at Amazon
Obliq Bumper Case
For a slimmer, yet protective cover the Obliq Bumper Case keeps a simple design with its all-in-one shock absorbent TPU material. Along with access to all the LG V10's features there's a nice grid pattern texture on the back that feels nice in the hand and adds a fair amount of grip. While the screen is faced down, the case elevates the device enough to keep away any scratches or scuffs. Since there isn't an extra layer with this skin case it keeps a low profile, minimizing the bulk factor quite a bit.
See at Amazon
OtterBox Defender Series Case
OtterBox has opted to manufacture their iconic Defender Series Case for the LG V10 for the every day rugged user. This heavy duty case has all the features we've come to expect including an internal foam padding, synthetic rubber slipcover, inner polycarbonate shell, and even a durable swivel holster to snap it all into at your side. Keeping the V10's display safe from scratches is their integrated screen protector alongside those silicone port plugs that you either love or hate. Those after serious protection for their LG V10 can't go wrong with this cover.
See at OtterBox
What's your favorite LG V10 case?
Those are 5 of our favorite cases for the LG V10 that will do a great job at protecting the device from damage. Whether you've found one on our list that you're interested in or you're already using a case that works for you, let's hear about it in the comments!
