If you're looking for better battery life for your Evo 4G, check out this extended battery from Seidio. The Innocell 1750mAh battery is the same size as the one that comes with our Evo, but it has 17 percent more power available, to keep you up and running longer. And because it's the same size, it doesn't add any bulk to the Evo 4G, or require a replacement door. The Seidio Innocell 1750mAh extended battery is available now in the Android Central Store for $49.95. (Sponsored post)
Sponsored Post
Seidio Innocell 1750mAh Extended Battery for Sprint HTC Evo 4G
This deal is expired
