Find the latest HTC ThunderBolt accessories
I'm not sure what I like more about this Mobi Products Hard Shell Case for the HTC ThunderBolt -- this red color here is dark red. A mean, dark red. It's like someone took a sort of metallic red and painted over the blackest of blacks, and the blackness is threatening to return. If light's not hitting it directly, the edges of the case cast shadows that I could swear are moving.
So, yeah, I'm digging the color. (It also comes in black and purple.)
And then there's the fact that it's your standard Mobi Products hard shell case. It comes in two pieces that, separately, don't seem very substantial. But snap them together, and your phone's protected from dings and scratches. The case doesn't add much bulk to the phone, but it's just thick enough to keep the screen from touching a table if left face down. You've got cutouts for the ports and buttons, as well as the kickstand.
And, again, there's that awesome color.
The case comes apart easily enough if you need to take it off, but there's also no movement if you squeeze at the seams. Speaking of the seams, the point where the front of the case and the back come together -- that's about the only ding we'll give this case. We'd love to have the seams a tad more invisible. It's not a deal-breaker, just a fit-and-finish sort of thing.
You can get the Mobi Products Hard Shell Case for the HTC ThunderBolt for $12.95 from the Android Central Store in red, black or purple. Check out more pics after the break.
Newest HTC ThunderBolt cases
Best selling HTC ThunderBolt cases
- Related devices:
- Filed under:
- Tags:
3331(forum posts)
