Tech Armor HD Ballistic Glass
When regular protectors just won't cut it, this tempered glass shield retains top-notch clarity while handing impacts like a champ.
When you're using a typical PET screen protector, there are certain kinds of drops that aren't ideal for the protection they deliver. And, that's where tempered glass shields fill in the gap. Tech Armor's Ballistic Glass Protector for the Galaxy S6 has been laser cut, polished, with rounded edges for a perfect fit on your display — retaining its pristine look while offering next-level scratch and impact resistance. Jump past the break to see what's inside and check out a quick and easy installation video.
What's included?
With Tech Armor's HD Ballistic Glass you get a single tempered glass screen protector, cleaning wipe, micro-fiber cleaning cloth for managing fingerprints and smudges, squeegee for smoothing out bubbles, dust removal tape, and installation instructions. The 99.99% touch screen accuracy and clarity that this Ballistic Glass provides is what makes it an excellent option over the competition.
Right out of the box, you're fully prepped for a complete installation of your new Galaxy S6 tempered glass screen protector!
How do I apply mine?
Before slapping on your new Ballistic Glass Protector, make sure you use the included micro-fiber cleaning cloth to wipe away any existing fingerprints or smudges on your Galaxy S6's display. Then, go ahead and peel away the green Start Tab, revealing the adhesive side. Carefully align the protector on your display, being sure not to touch the adhesive side with your fingers. Once it's completely flat, simply tap the middle of the display, then make an "X" with your finger across the screen. From this point, you can use the squeegee to smooth out any bubbles that may be around the edges. And you're finished!
Why Tech Armor?
These guys have been around long enough to build up thousands of awesome reviews on their products across Amazon, and they're extremely committed to excellent customer service, which we're huge fans of. Unlike a lot of the competition, Tech Armor's products are reasonably priced — especially for the great quality they deliver. With every purchase comes a no-hassle lifetime warranty that includes any manufacturer defects. It's good stuff, is what we're saying.
Buy yours today!
Check out Tech Armor's HD Clear 3-pack for Galaxy S6
