There's just hours left to save big on the ultimate 163W car charger
Baseus PrimeTrip VR2 Max
(Image credit: Apoorva Bhardwaj / Android Central)
I'll admit that I didn't pay much attention to my car charger; it did the job and had two ports, and that was all I needed. But then Baseus came along and showcased what it can do in this category; the PrimeTrip VR2 Max is designed to take things to a whole new level, thanks to 163W of power delivery and four charging ports in total.
But what I like the most is that the charger comes with two retractable cables. I recently used a UGREEN car charger that has a built-in retractable cable and thought that was cool, but it isn't as good as what Baseus is offering. Oh, and the best part? The VR2 Max is down to just $29 right now, a sizeable 40% discount on its $49 retail price. Need other tech? See everything on sale now at Amazon.
Baseus PrimeTrip VR2 Max 163W Retractable Car Charger
Baseus PrimeTrip VR2 Max 163W Retractable Car Charger: was $49 now $29 at Amazon
Honestly, there are very few products that are as easy to recommend as this one. The inclusion of two retractable USB-C cables makes all the difference, and if you need a new car charger, you should just get this.
✅Recommended if: You want a car charger that's designed to deal with cable clutter. Both retractable USB-C cables tuck into the body of the charger when not in use.
❌Skip this deal if: You don't need as many charging ports.
Alternative deal: UGREEN 90W Retractable Car Charger — $27 on Amazon
Look, I can talk about the power budget and go into detail on how the four ports allocate the 163W available, and how the USB-C1 port goes up to 67W. But I don't need to do all that; all you need to know about this car charger is that it has two retractable USB-C cables — each extending to 31.5 inches — and they neatly tuck into the charger when not in use. There's an additional USB-C port alongside USB-A connectivity if two cables aren't enough.
Oh, and did I mention that the charger swivels? It has 180-degree vertical rotation and 270-degree horizontal rotation, so you can easily route the cables to whichever part of the car you or your passengers are sitting in. I used this charger for the better part of two months now, and it has been nothing short of brilliant.
Okay, enough talk. If you're in need of a new car charger, I really don't know of anything else that's as good as this. Baseus knows how to make reliable charging gear, and I didn't see any issues using this charger with a half-dozen phones. And costing just $29, you won't find another car charger with as many features.
For everything on Amazon Prime Day, head to our ultimate buying guide.
Harish Jonnalagadda
Senior Editor - Mobile
