This hard case rocks transparent, dual-layer protection against damage for your LG G4.
It's hard to find a decent case for the LG G4 that's compatible with the leather battery door. Many claim they'll fit, but end up putting way too much pressure on the leather, stretching it out, and just looks terrible. We got our hands on Case-Mate's Naked Tough Case this time around, and found that while installation is certainly easier on the plastic back of the LG G4, the fit around the leather was surprisingly good.
The case comes with a completely clear polycarbonate shell and a matching TPU bumper. You'll find openings for the microphone, top IR ports, as well as charging and auxiliary ports on said bumper. It's also not as clear as the back shell, rather a bit more cloudy. As you'd expect, there are precise cutouts for the camera, power button, and speaker on the back.
Installation is a bit tricky if you plan on slapping this clear cover on your leather-backed G4. Always wrap the bumper around the phone first — regardless which cover you're rocking. Slide the phone into the shell - bottom first, then hold the bumper in place while you fit the rest. When it's installed properly, it looks great underneath that smooth plastic. It's a tad on the slippery side, but the TPU bumper helps to enhance your grip around the edges. The shell also features an anti-scratch finish that's great for keeping a clean look. Fingerprints are still an issue, but they don't show up too badly. When placing the LG G4 face down, the bumper keeps it elevated enough from any surface — leaving the display scratch-free as well.
Final thoughts
Although the Case-Mate Naked Tough Case isn't advertised for both battery door types, this cover offers one of the better fits we've seen thus far. If you don't mind putting in the extra effort for a clean installation, the end result is worth it. You can snag this case from ShopAndroid right now for $24.95 if you're interested. Oh, and use coupon code: CJ715 to save yourself an extra 20% — valid through tomorrow.
Buy from ShopAndroid
