If you want to maximize the functionality of your smart lock, you should seriously consider the silver Smart Lock Pro and August Connect bundle, which is discounted to $165 on Amazon right now. That's the lowest price we've ever seen for this bundle, which usually sells for around $230 and sometimes goes as high as $280. This even beats the deals we saw for the holidays last year. If you'd prefer the dark grey version, it'll only run you $10 more. Note that these deals are part of Amazon's Prime Day celebrations, which are exclusive to Prime members. Sign up here for a free 30-day trial if you don't have a membership yet.
Stay Connected
August Smart Lock Pro plus August Connect 3rd-generation
This is a fantastic price, beating out any other we've seen.
$165.00 $230.00 $65 off
The Connect serves as a bridge between the 3rd generation smart lock and your smart home ecosystem. August's 3rd gen smart lock gives you wide-ranging control over your front door. With August's Door Sense, you'll be able to know if your door is closed and locked from anywhere. You'll be able to control access, too. For example, you can create guest access for visitors that only lasts for a few minutes or a few weeks. You can track the door's activity 24/7, too. The lock works with most single-cylinder deadbolts, and you'll be able to keep your existing locks and keys. It will lock automatically behind you and unlock when you approach. This lock uses the Z-Wave Plus wireless protocol, which is why you need the Connect.
We may earn a commission for purchases using our links. Learn more.
