I can't believe the Beats Solo 4 are half off - score 50-hour battery life for under $100
Beats Solo 4
(Image credit: Tshaka Armstrong)
Over-ear headphones can get expensive quick — I routinely test models between the $400 and $600 price points. If you're on a budget, going with an on-ear pair of headphones can be an excellent way to save without sacrificing quality. On-ear headphones come with perks of their own, like lightweight designs and secure fits.
Beats Solo headphones have been the default for on-ear headphones for years, and the Solo 4 model is $100 off for Prime Day. For a limited time, these headphones are just $99.95 on Amazon, meaning you're technically saving more than you're spending (by five cents). I've tested the Beats Solo 4 personally, and found a handful of ways they beat more expensive headphones.
Beats Solo 4
Save $100
Beats Solo 4: was $199.95 now $99.95 at Amazon
The Beats Solo 4 are a pair of basic, lightweight headphones with up to 50 hours of battery life. They support features like spatial audio and dynamic head tracking. You can use the Solo 4 with iOS or Android without losing features.
✅ Recommended if: you need a secure pair of on-ear headphones; you want headphones with week-long battery life; you value a USB-C port and 3.5mm jack for lossless audio.
❌ Skip this deal if: you prefer over-ear headphones; you have more to spend and would rather upgrade to the Beats Studio Pro (only $50 more for Prime Day).
The difference between on-ear and over-ear headphones is simple. On-ear headphones, like the Beats Solo 4, have ear cushions that rest directly on your ears. They're typically smaller and lighter, with a higher clamping force, as a result. This makes headphones like the Solo 4 ideal for working out, where you don't want to have over-ears slipping off your head during a lifting session.
By comparison, over-ear headphones like the Beats Studio Pro fit your ear inside the cushions, which some find to be more comfortable. I tend to like over-ear headphones, but the tradeoffs are size, weight, and price.
The Beats Solo 4 stand out among the competition with numerous connection methods. You can use them wirelessly with iOS and Android, and there are physical power, play/pause, next/previous, and volume up/down buttons. Better yet, there's both a USB-C port and a 3.5mm jack for wired connections.
The USB-C port can be used for charging, and when fully charged, the Solo 4 last for up to 50 hours. If they die, the 3.5mm jack supports fully analog mode — you can use them with an aux cable without power. The USB-C port can also be used for wired audio. You have a ton of options, and the two wired modes support lossless audio.
It's worth noting that the Beats Solo 4 lack active noise-canceling, and this cost-cutting measure helps them cost so little. If you can look past that, these are a surprisingly great pair of headphones for slightly under $100.
Brady Snyder
Contributor
Brady is a former contributor for Android Central, who wrote for the site from 2023 to 2026. With a focus on news, phones, and audio, he spent years reporting and commenting on all things related to consumer technology.
Brady reviewed Apple, Google, Samsung, and Motorola phones for Android Central, and attended industry-wide events like IFA and MWC on behalf of the publication. He holds a bachelor's degree in journalism from St. John's University.
His work has been published in XDA, Android Police, Android Authority, MakeUseOf, and SoundGuys, among other sites. When he isn't experimenting with the latest tech, you can find Brady running or watching Big East basketball.
