Fast and wireless!
If you're in the market for a new wireless charger, you won't want to miss this one. RAVPower is currently offering its fast charging pad for just $7.49 when you use the coupon code 9D4N5YKB during checkout at Amazon. This is a savings of 50% and makes it super affordable to have one of these in every room of your home or office. This is a fast wireless charger, but you need to buy a wall plug that supports it. You can pick up a compatible plug for just $8.49 if you don't already have one.
  • Fast Charge & Wide Compatibility: Fast Charges up to 10W Qi-enabled and Quick Charge devices like the Samsung Galaxy S8 / S8+ / S7 / S7 edge / S6 edge+ / Note8; or charges Qi-enabled, non-Quick Charge devices at a standard 5W
  • Tips for Optimal Usage: Charge full throttle by using a 15W or higher QC2.0 / QC3.0 adapter; simply equip your device with a Qi receiver if it's not Qi-enabled out of the box. Does not charge through metal phone cases or cases thicker than 3 mm
  • Safer Devices with Added Protections: Comes with overcurrent, overheat, over-voltage, and short circuit safeguards; standing behind our products, we include an 18-month warranty
  • Discreet, Informative LED Indicator: Low-key, yet fully visible LED light turns blue or green to indicate whether it's in standby or charging respectively
You'll want to make sure you remove any metal cases or magnetic objects from the back of your phone before you use this (or any) wireless charger.
See at Amazon
