Body Glove Flex/Chrome Snap-On Case for T-Mobile Vibrant
If you want a case with some serious protection but without the oversized rugged look, check out the Body Glove Flex/Chrome case for the T-Mobile Vibrant. The three-piece case features a rubberized back cover, chrome front bezel and a removable belt clip.
Body Glove Flex/Chrome Snap-On Case for Samsung VibrantYou start by putting the phone in the back cover, and then snapping on the front bezel. It's a pretty sung fit, and you won't have to worry about it coming undone. The back cover is clad in a textured rubber, giving it great grip in the hand, or on a table or car dashboard. There are cutouts for all of the buttons, ports and microphone. And the case is thick enough so that the camera lens is well-protected if the phone is left face up.
The belt clip fits snugly and secures with a snap mechanism. You release it with a spring-loaded button on the bottom of the clip. If you want, you can remove the belt clip nub from the back cover of the case and replace it with a flat insert. That lets it ride much more comfortably in your pocket.
We've got loads more pictures after the break. The Body Glove Flex/Chrome case for the T-Mobile Vibrant is available in the Android Central Store for $24.95.
Body Glove Flex/Chrome Snap-On Case for Samsung VibrantBody Glove Flex/Chrome Snap-On Case for Samsung Vibrant
Body Glove Flex/Chrome Snap-On Case for Samsung Vibrant Body Glove Flex/Chrome Snap-On Case for Samsung VibrantBody Glove Flex/Chrome Snap-On Case for Samsung Vibrant Body Glove Flex/Chrome Snap-On Case for Samsung VibrantBody Glove Flex/Chrome Snap-On Case for Samsung Vibrant Body Glove Flex/Chrome Snap-On Case for Samsung Vibrant
There are 7 comments. Add yours.
joshuat says:
looks pretty sweet. Might check it out. After I finish angry birds of course
Is this any less bulky than the rubber casing they sell at the T-Mobile store?
boxer2 says:
It makes the vibrant a whole lot less slippery and makes it the perfect size IMHO. My gal has the gel skin which I didn't care for as much, harder to pocket. Its fine for her though, she carries in purse. I don't have much use for the clip but nice to have if you need it. I imagine the plasticized chrome trim will start to look shabby after awhile but so far so good after 30 days. Good purchase.
boxer2 says:
I should add that it does feel very secure and tight fitting. The cutouts for the controls make it easier to find them. I guess the raised trim adds a little protection to the display edges.
parmijo11 says:
I have had it since day one. Its a little more bulky that the rubberized case but certainly worth it. Have used for over two months and makes the phone a little more heavy but still comfortable to hold and use. Plus I have Ghost Armor on the screen so I'm set.
mformarcee says:
Can this case be used with the european version of galaxy s? As far as I know they have the same size.
Kwaii64 says:
its the same exact size so yes @ mformarcee.
nice pics, but upclose it feels so flimsy and cheap. big bummer. my opinion is that it's $10-15 overpriced.
