Internal renders of a device alleged to be the Sony Xperia Z4 have leaked, showcasing a design that is largely similar to what we're used to from Sony.
Sony Xperia Z4 leak
Sony's upcoming Xperia Z4 has been leaked in renders showcasing the front and rear of the device. According to the leaker, the renders in question are for use within Sony to highlight what the handset will look like. As such, the final design may undergo minor changes, but for now, here's a first look at Sony's upcoming flagship:
The images reveal an exposed micro-USB port, slits at the top and bottom for stereo speakers as well as a single flap on the left side, presumably for housing the SIM card and microSD card. It appears magnetic charging pins — seen on many Sony phones in recent years, for use with the manufacturer's proprietary docks — have been abandoned. In terms of specs, the leak mentions that the Xperia Z4 will have dimensions of 146.3 x 71.9 x7.2mm, which is nearly identical to the 146 x 72 x 7.3mm dimensions boasted by its predecessor.
What do you guys think of the upcoming Xperia Z4, should these renders to turn out to be accurate?
Source: NoWhereElse
