Conventional wall outlets are great but can be made so much better by swapping them with TopGreener's dual USB wall receptacles. Normally they sell for up to $20, but right now they are marked down to just $15.45 each via Amazon. If you want one of the colored versions, they are still at the full price.
Power To The People
TopGreener dual USB wall receptacles
It's time to turn your standard wall outlets into more functional ones without going broke. Thankfully, these Topgreener outlets are fitted with dual USB ports and are nearly 25% off today.
$15.45 $19.99 $5 off
Each one has two AC plugs and two USB ports, which turns a space that used to charge two devices into one that can easily charge four. The USB outlets have a 2.4A output to quickly charge your devices. Installing this receptacle is quite simple, though there are a few things to know. Be sure to check out this video before trying it for yourself. If you aren't comfortable trying it on your own, most local electricians charge very reasonable rates for swapping these things out.
We may earn a commission for purchases using our links. Learn more.
