You don't need some expensive security system to keep an eye on your home. The eufyCam 2C Wireless Home Security System is both affordable and easy to use, and it allows you to use your phone to view your video feeds from anywhere in the world. Today you can pick up the 2-camera starter kit on sale at Amazon for only $189.99 at Amazon. That's thanks to a $40 direct price drop as well an on-page coupon taking a further $10 off. The discount is limited in time, so be sure to snag this set at one of its best prices ever before it's gone. The add-on camera is also discounted at $84.99.
Eufy cordless stick vacuums and robot vacuum cleaners
As low as $140
Choose from a cordless stick vacuum or a robot vacuum. The cordless vac includes 120AW suction power for 8 minutes or 25 minutes in standard mode. Helpful for getting into tight spaces. The robot has 1300Pa suction and lasts up to 100 minutes.
Eufy Security Wi-Fi 2K resolution video doorbell
$119.99 $160.00 Save $40
You'll get a wireless chime you can use somewhere else in the house to hear the door wherever you are. Has a 2K resolution image with advanced HDR and distortion correction. Includes two-way audio, motion detection, and smart alerts.
Eufy RoboVac 15C Max Wi-Fi connected robot vacuum cleaner
$175.99 $ Save $
Comes with super strong 2000Pa suction so it can pick up even stubborn dirt. BoostIQ feature will even boost the suction when you need it. Lasts for up to 100 minutes. Use the EufyHome app and connect it to your smart home for more control.
Eufy Spaceview Security by Anker baby monitor camera bundle
$129.99 $170.00 Save $40
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Can pan 330-degrees and tilt 110-degrees so you can see the whole room. Get instant alerts. Has a range up to 1,000 feet.
Eufy Security SpaceView 720p video baby monitor with night vision
$109.99 $160.00 Save $50
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Includes a wide-angle lens for when your baby starts moving around more. Get instant alerts. Has a range up to 1,000 feet in open area.
This kit comes with two wireless cameras and the HomeBase 2, which is the base station you need to connect everything together. The cameras provide live streaming and video recording in 1080p HD resolutions. They also use a 135-degree field of view that lets them get a good look at everything in the vicinity. You'll be able to fully see what's going on in or around your home. They also have detailed night vision.
These cameras are designed with a powerful battery that will last for up to 180 days on a single charge. Not only do you get to skip the inconvenience and tediousness of setting up wired security, but you also don't have to worry about recharging the wireless battery for six months at a time.
You can use your phone or Echo device to receive smart alerts from your cameras when they detect intruders. The cameras use human detection technology, which helps them distinguish body shapes and facial patterns. You won't get bad alerts that waste your time. You'll know when your camera has spotted a human or a stray cat instead.
The IP67 rating for the cameras means they resist dust, dirt, and water. The number 6 means there's nowhere on the camera for dust to even get in. It is completely protected. The 7 rating means not only are the cameras protected from weather like rain, but you could actually immerse them in water up to one meter in-depth and they'd be fine. Very impressive for cameras you're definitely going to want to use outside.
