Android Central Verdict
The EBO Max is one of the most ambitious robots from Enabot. It has all the usual great specs that all EBO robots have: two-way comms, remote control via app, wheels to move and a charging dock to return to, cute movements and audio clips, and lovable eyes that move in a human-like way. But what really sets the EBO Max apart is its ability to remember, to converse in natural language, and to recognize patterns. It has an AI-powered mind that grows over time, soaking up information like a sponge and becoming more and more useful and relevant to your household with every passing day.
Reasons to buy
Improved mapping and object detection
Smooth connection and remote controls
Crisp 4K footage with night vision
Knows even more tricks and can do cat and dog voices now
Scheduling and patrolling feature is handy
Excellent fall detection
Handy extras like pet and family detection, adjustable eyes, and customizable voices
Reasons to avoid
No Alexa or Google Home integration
AI features are a little glitchy
Tends to run hot occasionally
Enabot's cutesy robots on wheels are always fun contraptions, but the most perplexing thing about them is their animal magnetism. Cats can't seem to get enough of them, as witnessed not just by me but by my colleagues as well. I genuinely wonder if Enabot rubs catnip on their robots at the factory level before shipping them out.
This is perfect, however, because Enabot's smart family robots are primarily advertised as pet companions, with a secondary focus on family companionship and home surveillance. It's an all-in-one security camera on wheels that monitors your beloved family members, whether two-legged or four.
The EBO Max isn't cheap
View Original
View Original
Enabot launched the EBO Max family bot on March 31, 2026. Priced at $599.99, it is the second most expensive such robot offered by the brand. You can also buy a EBO Max Style Pack for $29.99 that has four cosmetic add-ons, including deer antlers and rabbit ears.
The EBO Max comes with a charging dock, a 32GB SD card pre-inserted into the robot, an adapter, and a resetting pin in the box.
View Original
View Original
The EBO Max is a mid-sized robot, a lot smaller and more compact than the larger EBO X, but slightly larger than the EBO Air models. The charging dock is significantly smaller and slimmer than the EBO X and other models.
Just like other Enabot robots, you can easily take off the wheel tracks of the EBO Max for cleaning. The entire bottom unit with the wheel tracks slides off with a few clicks. This is also where the memory card slot is located.
Category |
Enabot EBO Max |
Camera |
8MP, 4K (3840 x 2160) resolution, 131° FOV, night vision |
Memory |
64GB local storage (47GB available), expandable up to 256GB via memory card |
Comms |
Speaker, microphone |
Connectivity |
Wi-Fi 2.4G, 5G |
Navigation |
V-SLAM Navigation |
Speed |
20cm/s-60cm/s |
Obstacle height |
≤12mm |
Climbing slope |
≤15° |
Battery and charging |
2,500mAh, 4–6hrs standby/video recording, up to 3hrs continuous movement, 3-4hrs charge time |
Hardware |
PC+ABS, brushed gear motor, 53dB operating noise |
Dimensions |
129 x 127 x 117 mm, 750g |
What can this robot do?
Before setting the EBO Max up, it was really important to let my cat sniff the robot to his heart's content. This helped ease him into a new element in the house, as cats tend to hate change and can be very nervous around moving objects.
Once he was happy with the smell and familiarized himself with it, I set up the EBO Max charging dock and turned it on. My cat was more curious than afraid, and he even started cuddling with the bot right away.
Initial setup involves the EBO HOME app, which immediately gives you a comprehensive walkthrough of the robot's capabilities. This is helpful because there's a lot to learn and explore in the app, which is the robot's main control center.
The EBO Max bot can use V-SLAM Navigation to map out your house. It can recognize family members once you've registered their faces and voiceprints, and once those are saved, you can set up voice calling settings for those members. If a fall is detected, you can select certain family members to be notified.
You can change the style and color of the "eyes" of the EBO Max robot, which are incredibly expressive. They follow you around, almost in a sentient manner, which can be cute and human-like — but also really creepy at 3 AM. There is a sound localization feature that makes the robot turn to you when it hears your voice. Thankfully, the bot can be scheduled to "close its eyes" during your chosen "Do Not Disturb" hours.
View Original
View Original
View Original
View Original
View Original
Because the EBO Max has two-way comms, family members can even receive voice calls when fall detection is triggered. You can take this one step further with activity detection, so if no movement is detected for your selected number of days, you and your chosen family members will be notified.
The robot can be scheduled to patrol and play or monitor people and/or pets at home during your selected hours, and you can set it to smartly patrol the house on your chosen route once the house is mapped. Additionally, you can adjust event recording settings to automatically record photos and videos of interactions. When the EBO Max runs low on battery, it returns to the charging dock on its own.
The EBO Max can be remotely controlled via the app as it has Wi-Fi. It sports an 8MP camera with a 4K resolution, a wide 131° field of view, and night vision, so the image quality is very crisp and clear in diverse lighting scenarios.
View Original
View Original
View Original
View Original
View Original
View Original
View Original
You can queue actions and sounds, individually or together, when playing with children or pets. There are plenty of cat and dog sounds, as well as many movements, including some of the best actions from other EBO bots, like the figure-eight dance from the EBO X.
Everything from the robot's movement speed and the audio and call volume settings can be adjusted too. There's no manual mic and video shut-off button or shutter, though, which is a bit of a privacy oversight.
However, the "Do Not Disturb" mode can be used as an alternative. You can set the robot's active "wake up" hours, and even choose to have the screen (or the "eyes" of the bot) automatically shut off during your selected DND nighttime hours.
Because of course there's AI
The EBO Max family bot has a wide array of useful AI features. You start by saying "EBO EBO" to initiate conversations or give instructions, all in natural language. You can use the "EBO EBO, follow me" command to make the robot leave the charging dock and follow you around the house.
Other features include setting timers, reminders, or alarms; asking about the weather; asking the robot to find a certain family member; and more.
You can change the AI voice tone or clone your voice to be used as the robot's voice using the Pet Parrot feature. So, the EBO Max can read your text when you send it to the robot.
Enabot gave the EBO Max family bot an AI-powered brain, so it literally learns from all the information it absorbs and gets smarter the longer you use it. This adaptive behavior means the bot remembers patterns and perceives its surroundings, and it can even role-play depending on the role you assign it.
You can also assign more complex commands. For example, you could say, "I'm going on holiday for two days starting tomorrow. Patrol the house three times a day and alert me of any unusual activity. Record a video of any movement," and the EBO Max robot will do just that.
Eventually, it can even distinguish memories and learn about your habits, hobbies, preferences, and daily home life. This can be helpful for questions like "Did Grandma take her morning medicine yesterday?" or similar scenarios.
Using the AI functions sometimes causes the robot to run a little hot, and the AI also hangs or glitches at times, especially after being asked a few questions simultaneously. Also, when you're using an AI feature, this prevents you from queuing movements or animal sounds when remotely controlling the robot.
Unfortunately, there is no smart home integration with Gemini or Alexa, so you miss out on automations and options like playing music or switching on your TV. There is also no Bluetooth speaker mode. I find both features incredibly useful on the EBO X, so this was a bummer.
Should you buy the Enabot EBO Max?
In many ways, this is the smartest robot Enabot has ever made, although it's missing smart home integration and some refinement. Native Matter support would've made this a monumental leap in the smart home world.
Once the EBO Max builds memories and learns enough, and with the help of firmware updates, I truly believe the small hiccups will iron themselves out. Enabot is very good with updates — I got one as soon as I installed the EBO Max robot.
At $599, the EBO Max is a lot cheaper than the $999 EBO X, which includes Alexa and physical shut-off buttons for the mic and the camera. So getting a large portion of its features and an AI-powered brain that gets wiser over time, all for $400 cheaper, is a bargain if you ask me.
If you need a smart home camera that can follow and monitor your loved ones or even keep your kids and cats entertained, EBO Max is an outstanding family robot for you.
Smart-maxxing
The Enabot EBO Max is an AI-powered family robot with crystal-clear cameras, loudspeakers, a clear mic, and plenty of handy features. The EBO Max can grow to be a member of your household, a bot that monitors the well-being of your family, keeps them company, and entertains your pets, all while patrolling the house every night and alerting you to suspicious activity.
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
