I created Harry Potter style moving portraits with the Homture Magic Frame
Homture Magic Frame
(Image credit: Namerah Saud Fatmi / Android Central)
Gadget Weekly
Inspector Lloyd
Join Namerah Saud Fatmi as she explores the cool, quirky, and sometimes downright odd world of smartphone accessories, gadgets, and other nerdy toys every week.
Bringing pictures to life takes a whole new meaning with the Homture Magic Frame. This enchanting digital photo frame is loaded with AI goodies and smart sensors, making your still shots move dynamically.
What truly makes this a magical experience is the motion sensor detection. The frame only triggers movement in your static photos once it detects motion nearby. And that is exactly why it feels like a Harry Potter style moving portrait — it literally senses movement and reacts!
The Homture Magic Frame can be set up as a gift or for personal use
Homture Magic Frame
Priced at $139.99, the latest Homture Magic Frame version was launched in October 2025. The 10.1-inch frame has a Full HD+ (1920x1200) resolution, 64GB of local storage, a one-year warranty, and a 30-day return period. There is a stand built into the back that can be used both horizontally and vertically, and a proprietary power cord is included in the box.
The Homture Magic Frame can be set up for your own use or as a gift for someone else to use and own. This can be done by scanning the QR code on the box, or by sending a digital gift code if it's a long-distance present.
The Homture Magic Frame uses Wi-Fi to connect to the Android or iOS app. Once the frame is paired with your phone, you can add photos from your smartphone's gallery to the Magic Frame.
It is a fairly straightforward setup process that requires you to simply follow the steps indicated on the Magic Frame once you turn it on. The setup process takes about five minutes, including time to install the Homture app on your phone.
The moving photos are AI-powered
The moving pictures are created by using the AI Magic feature within the Homture app. You can select which photos you want to bring to life and what actions you would like them to do. For example, I created an AI Moment of my cat waving at me. Every time I step near the frame, my cat waves hello!
The sensor isn't perfect, and sometimes it doesn't detect movement. To address this, you can tweak the motion detection settings in the frame's Settings menu and choose from high, medium, or no trigger probability options to make the dynamic photos move more or less frequently.
Once these "AI Moments" are created, you can send them to the frame. There are several options within the app, such as the ability to show a certain picture or AI Moment immediately, add and delete pictures from the frame, hide pictures, like pictures, and download pictures. So if the frame is a gift, the recipient can add, remove, or download whatever pictures you loaded for them beforehand.
It is certainly cool, but is it worth spending money on?
Homture Magic Frame
One big drawback is that the Homture Magic Frame requires AI credit points to create these dynamic portraits. Each moving photo or AI Moment consumes 100 points. You get a 2,000-point card for free with the frame, which translates into 20 AI-generated videos or AI Moments.
AI credit points can be topped up later as well, with 500 credits priced at $4.99, 1,000 credits selling for $9.99, and 2,000 credits going for $19.99. Prices vary per region.
As much as I also wish for Alexa or Google Home integration, that would likely just drive up the price of the smart frame even more.
With the right curation of photos and videos, the Homture Magic Frame can be the most thoughtful gift ever. At its current price, it is a reasonable purchase, cheaper than many alternatives. Just be careful about how you spend your free 2,000 credits so you don't need to purchase any for a while.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
