This T-Mobile feature could save your life someday (and you don't even need T-Mobile for it to work)
Holding a Google Pixel 10 Pro XL up to check T-Mobile T-Satellite connectivity
Years ago, you could go nearly anywhere outside of a city and have no cell coverage. Mobile networks have improved substantially since then, but there are still places that don't have adequate cell coverage for one reason or another. Thankfully, T-Mobile has an ingenious solution to fix this problem: satellite connectivity.
While some phones have had satellite connectivity for decades, modern smartphones only recently received the feature when Apple introduced it on the iPhone a few years ago. Since then, Google has adopted it on its Pixel phones, and T-Mobile has taken things further by expanding coverage to phones that were never advertised to have satellite connectivity in the first place.
T-Mobile calls this program T-Satellite, and it's available to both T-Mobile customers and subscribers to other phone carriers. The program uses StarLink satellites to connect to T-Mobile's Network anywhere you can see the sky, which substantially opens up the coverage possibilities when compared to traditional cell networks.
What is T-Satellite?
The T-Mobile T-Life app on an Honor Magic V6
T-Satellite is the name of T-Mobile's satellite connectivity service, which operates using newer StarLink satellites. These satellites have a new kind of cell radio that can transmit via the 1980-2000 MHz spectrum, using T-Mobile's FCC-authorized LTE Band 25. This means that phones that support T-Satellite can automatically switch between T-Mobile's terrestrial Network and the StarLink-based satellite Network on the fly to ensure that you have connectivity 99% of the time.
Because of this, T-Mobile says its T-Satellite service can be used across over 500,000 miles in the U.S. that aren't covered by any other cell phone service. T-Satellite is also available internationally in select countries, including Canada, New Zealand, and Japan.
Other satellite-based connectivity with phones like the iPhone, for example, requires you to point the phone toward a satellite to initiate contact. This also means that connectivity is limited to basic text messaging and is only intended for emergencies. T-Satellite doesn't require you to hold your phone a certain way because it connects via an LTE channel, making the experience seamless.
T-Mobile logos in 16:9 aspect ratio
(Image credit: Future)
You can use full voice and data services through a specific set of approved apps. Thankfully, this includes common apps like WhatsApp, Google Maps, AllTrails, AccuWeather, X (formerly Twitter), and even MMS texting, so you can send and receive pictures in addition to text messages. T-Mobile maintains a full list of compatible apps here.
Voice calls are made through WhatsApp, while users can text 911 from anywhere. You'll know you're using the T-Satellite service when the connectivity icon on your phone changes to show "T-Mobile SpaceX" or "T-Sat+Starlink" in the status bar. Compatible apps may also show a banner letting you know that you're connected via satellite.
T-Satellite isn't as fast as T-Mobile's regular 5G Network, but since it's available virtually everywhere, that's an okay trade-off. The company launched this service in 2025, and things have only gotten better since then, making this a must-have service in the modern era.
Is my phone is compatible with T-Satellite?
T-Mobile's very magenta dialer app on the TCL NXTPAPER 70 Pro
T-Mobile T-Satellite is available for T-Mobile and non-T-Mobile customers. T-Mobile customers on any of the company's "Experience Beyond" plans can use the service without additional fees or add-ons. Folks using other carriers (like Verizon, AT&T, etc) can sign up for T-Satellite service separately for $10 per line per month via the secondary SIM on your phone.
T-Mobile says most phones sold in the last four years are compatible with T-Satellite, but I found that doesn't seem to be the case. What T-Mobile likely means is that most phones sold through its distribution channels and stores are compatible, but a significant number of smartphones made over the past four years don't appear to work with the T-Satellite service.
The Razr Ultra 2026 on a table next to the Razr Fold
(Image credit: Derrek Lee / Android Central)
I tested phones from several phones from major brands not sold by T-Mobile and found that none of them are compatible. That includes phones from brands like OnePlus, Oppo, Nothing, Honor, RealMe, and Xiaomi. Phones officially sold through T-Mobile channels, like Google Pixel, Samsung Galaxy, Apple iPhone, Motorola, and even the TCL NXTPAPER 70 Pro, all work splendidly with the service. Thankfully, T-Mobile regularly runs great deals so you can get a compatible phone.
To find out if your phone is compatible, head over to T-Mobile's official compatibility tool and input your IMEI and EID numbers to check. To find these numbers, open your phone's system settings (found in the app drawer) and scroll down to About Phone. Most phones show these numbers in this section, although you may also have to open the Status section (under About Phone) to find them.
How to enable T-Mobile T-Satellite
If you're already signed up for a compatible T-Mobile plan (as discussed in the section above), or you have a separate SIM just for T-Satellite, you should be all set. It's good to double-check and make sure things are working before you venture out, though, so follow these steps to ensure that T-Mobile T-Satellite is enabled:
1. Open your phone's system settings. On most Android phones, this is found by tapping the settings icon in your app drawer.
2. Open the Network & Internet section (Connections on a Samsung phone).
3. Select SIMs & mobile network.
4. Tap your SIM card in the list (not the toggle button to the right of it). On Galaxy phones, you can go directly to Satellite networks and skip the next step.
5. Select Satellite connectivity from the list.
If your phone doesn't support satellite connectivity, you will not find a Satellite Connectivity option in the menu.
The next screen will let you know if your phone is set up for satellite connectivity. On one of my T-Mobile plans, my Motorola Razr Fold shows that the plan doesn't support satellite connectivity features.
On another T-Mobile plan that supports T-Satellite, the connectivity section shows that data and messaging are included with the account, plus a list of all supported apps currently installed on the phone.
Now that you're all set up, enjoy advanced satellite connectivity anywhere you can see the sky. Keep in mind that any obstructions, including trees, signs, and buildings, could block your connectivity.
For the best results, get to a clear, open area and keep an eye out for the special "T-Mobile SpaceX" or "T-Sat+Starlink" in the status bar on your phone to know you're connected to T-Mobile's
Nicholas Sutrich
