B&H has a new set of Black Friday deals this morning. One of them is a bundle that includes the DJI Osmo Mobile 3 smartphone gimbal with a mini tripod and a carrying case all for just $89 total. That's $9 better than a deal we shared a couple months ago that featured just the Osmo 3 by itself so you're getting a lot of extra value with the add-ons. This bundle normally sells for around $139. It is a B&H flash deal, so don't expect it to last forever. The same bundle is $120 at Best Buy and that's technically on sale.
For your smartphone
DJI Osmo Mobile 3 smartphone gimbal with mini tripod and case
For using your smartphone to capture stabilized handheld footage. Step up to even more professional looking video. It's foldable and portable so it travels well. Includes the smartphone gimbal, a mini tripod to hold it, and a carrying case for all.
$89.00 $139.00 $50 off
Imagine how much better your smartphone videos would look if they weren't constantly impacted by your shaky over-caffeinated hands. If you want to use your smartphone to capture some really good video, the Osmo is the way to go. It can capture handheld footage without all the low quality and bad angles you're used to by just extending your arms. The Osmo Mobile 3 uses intelligent ActiveTrack AI and a lightweight design to create cinematic movement and help you capture moments. The ActiveTrack 3.0 tech can automatically follow body shapes so it automatically tracks human subjects.
VPN Deals: Lifetime license for $16, monthly plans at $1 & more
You can control it all directly with the DJI Mimo app that's accessible on iOS and Android. The app has other features like motion timelapse, zoom control, panorama, and more. The gimbal supports large smartphones and has a new Sport mode, which uses hand gestures for control. The stabilizer also has Bluetooth 5.0 for low latency smartphone control.
The Osmo 3 is compatible with any smartphone up to 3.5 inches wide, including Android and iOS smartphones. That's large enough for even modern phones like the iPhone 11.
The battery lasts for about 15 hours and charges via USB-C. You can also use the USB-A ports on the handle to charge your phone or other device while using the Osmo 3. DJI backs it up with a one-year limited warranty.
We may earn a commission for purchases using our links. Learn more.
