Best wireless car chargers and mounts
For drivers with long daily commutes, the best wireless car chargers are an excellent investment. Beyond the fact that plugging and unplugging your phone can be a pain, most car chargers come with a mount or phone holder that places your phone closer to eye level, so you're not glancing down when your gaze should be on the road. Qi wireless chargers have already started creeping into our offices and homes. If you're using a Qi-enabled phone, you should absolutely grab one of these chargers and go wire-free in the car too.
These are the best wireless car chargers and mounts
Sensors and magnets and springs
The biggest differentiators when picking the best wireless car charger are going to be how the mount attaches to your car, and how the mount grips your phone. If you prefer a no-nonsense mount that uses the standard springs, then the iOttie Wireless Car Charger is a great choice. It's a bit bulky in the dashboard style, but it has a suction cup to easily stay on your window or dash, so long as it's not a ridiculous temperature out. Plus, the spring mounts tend to last well over a year before wearing out.
I prefer air vent models because they tend to fit a wider array of vehicles. Plus, the air from the AC blows over the mount and your phone, which helps keep them cool as wireless charging generates some heat. Something like the iOttie iTap 2 will definitely fit the bill if you agree.
Of course, before you buy any of these, check if your Android phone supports wireless charging. If not, you can always try a car phone holder or magnetic mount that doesn't offer charging, and then invest in one of the best car chargers separately.
Ted Kritsonis
Contributor, Audio Reviewer
Ted Kritsonis loves taking photos when the opportunity arises, be it on a camera or smartphone. Beyond sports and world history, you can find him tinkering with gadgets or enjoying a cigar. Often times, that will be with a pair of headphones or earbuds playing tunes. When he's not testing something, he's working on the next episode of his podcast, Tednologic.
With contributions from
