The weekend is the perfect time to save money and get some stuff you need. Many of these deals have dropped to prices so low we haven't seen them before.
Immersive
Acer ED323QUR 31.5-inch WQHD curved 144 Hz FreeSync gaming monitor
The monitor fluctuates regularly between $350 and 375. It has even gone as high as $400, but it has never dropped as low as today's deal.
$289 $370 $81
The screen has a pixel resolution of 2560 x 1440 with an 1800R curve. The response time is 4 ms with a refresh rate of 144 Hz, which makes it great for gamers interested in fast paced games. You'll also get FreeSync tech for reduced screen tearing and a zero-frame design for total immersion.
Cyber Monday may be over but these Cyber Week deals are still alive
If you're not a gamer, we've still got plenty of deals you might be interested in:
Smart Clean: Roborock S5 robotic vacuum cleaner and mop
The Roborock S5 uses smart navigation to map your house, plan routes, and work on a schedule. As long as there are no barriers higher than two centimeters, it can cross over them, clean, and self-recharge. The device is smart enough to avoid falling down the stairs, scratching up your house, and getting stuck.
$398.99 at Amazon
Tiny but Mighty: SanDisk 256GB Ultra Fit USB 3.1 flash drive
This high-speed USB 3.1 flash drive features read speeds up to 130MB/s. You could transfer a full-length movie to it in less than 30 seconds. It's compatible with laptops, car stereos, game consoles, and more. More than 1,690 users reviewed this flash drive with 4 out of 5 stars collectively.
$29.99 at Amazon
Do More: Xcellon 3-port and SD card reader USB-C hub
Convert your single lone USB-C port into something far more useful and functional. The hub includes three USB-A 3.0 ports and an SD and microSD card reader. Since it's powered through the integrated USB-C cable, you don't need an external power source. The adapter is plug-and-play.
$14.99 at B&H
Bluetooth Buds: BlitzWolf Bluetooth 5.0 True Wireless Earbuds
Code: THRFTRBW25. Featuring Bluetooth 5.0 and IPX6 water-resistance, these wireless earbuds are built to let you listen no matter where you go, whether that's outside on a run, to the gym, or even in the shower. Their internal battery can keep them powered up for three hours of listening time, and with the charging case that comes with them, you'll be able to quickly recharge them on-the-go up to five times before it'll run out of juice.
$37.49 at Amazon
Can It: Simplehuman 10-liter Slim Step Trash Can
This simplehuman 10-liter trash can features a strong pedal that opens the lid when you press on it, and even though this is a smaller trash can that's designed for tight spaces, it still offers the durability and feel of something much bigger.
$17.99 at Amazon
Get Online: TP-Link AV1300 Powerline Wi-Fi extender
This is a plug-and-play adapter that provides up to 1300 Mbps Ethernet through your power outlets. You can also use it for dual band 1350 Mbps Wi-Fi. If you need to get a stronger connection to your router but you're separated by walls, this is how to do it. You can plug into the adapter with the Gigabit Ethernet port for a hardwired connection.
$99.99 at Amazon
This is just a small sampling of the deals that the Thrifter team has uncovered today. If you want to keep up with everything that the crew is uncovering, be sure to follow Thrifter on Twitter and sign up for the daily deals newsletter so you never miss out on anything!
We may earn a commission for purchases using our links. Learn more.
