Best portable power stations 2025
These power stations are the ones to rely on when you really need power.
1. At a glance
2. Best overall
3. Runner-up
4. Best budget
5. Best for high output
6. Best fast charging
7. Best for solar
Whether you're planning a camping trip or the power just went out, one of the best portable power stations can help. They are compact, lightweight, and powerful enough to provide juice to your most crucial devices. That might be everything from small appliances to a laptop, phone, tablet, and more.
Many portable power stations have secondary features, too, like a built-in LED light, additional ports, and other useful extras that come in handy both at home and on the go.
Portable power stations vary greatly, however, in size and power. So, it's important to choose the right one depending on how and where you plan to use it. Along with power, you need to consider factors like size, weight, how quickly they recharge, and more. To help you narrow down the choices, we have put together this selection of the best portable power stations, organized by helpful categories.
At a glance
Best overall
The EcoFlow Delta Pro is the power station of our dreams, boasting impressive output, fast recharge time, and lots of outlets. At 99 pounds, it's a bit heavy, but the wheels help.
Runner-up
The well-balanced Bluetti AC200Max features wireless charging pads, a ton of outlet/port options, and maximum output of 4800W surge power and sustained 2200W.
Best budget
If you need an affordable power station on the go, the Explorer 300 features an ultra-portable design at just over seven pounds, plus a variety of ports and fast rechargeability.
The Anker 757 should meet all of your energy needs no matter where you are, thanks to excellent power output, lightning-fast recharge speeds, and a convenient LED area light.
Best Fast charging
The EcoFlow River 2 Max comes with a 512Wh battery and up to 1000W charging in boost mode. This battery pack is perfect for impromptu adventures with fast charging taking it to 100% in around an hour.
Best overall
Reasons to buy
Reasons to avoid
The EcoFlow Delta Pro is an imposing power station. From its power output to the utility it provides, is something that makes this stand out as the best power station. For starters, the Delta Pro is capable of up to 7200W of surge output and 3600W of sustained power. Accessing that juice is possible from the myriad of outlets and ports to run your electrical devices.
From charging up the best Android smartphones from one of its six USB ports, including a 100W USB-C PD that is perfect for recharging a powerful Chromebook like the Chromebook Spin 713, to running essential appliances during a storm outage, like your fridge or a heater, the EcoFlow Delta Pro can handle it.
For those who enjoy going camping in an RV or travel trailer, the Delta Pro is a dream. During my review, I used the solar generator a lot in my camper, leveraging the built-in 30A outlet to power my whole trailer. Monitoring the output from the companion app or on the helpful display is wonderful. The app also allows you to control many aspects of the unit, including charge capacity and charge rate.
When it comes to recharging the EcoFlow Delta Pro, you can do so from a wall outlet, solar, a car socket, or even an electric vehicle charging station. In fact, with the right combination of output options, the Delta Pro can recharge at a rate of 6500W.
Capping the Delta Pro experience off, EcoFlow has an excellent assortment of helpful accessories to go with the power station. The battery capacity can be tripled using expansion packs. There's a Smart Generator that runs off gasoline that can be triggered to turn on to recharge the Delta Pro automatically. You can get an adapter that will allow the power station to output electricity at 240V. There's even a smart home panel that will let the solar generator automatically and safely power your home if the power goes out.
The EcoFlow Delta Pro is a hefty, 99 lbs., and pricey power station. But the portable electrical opportunities it can provide are well worth it if you can afford it.
Runner-up
Reasons to buy
Reasons to avoid
Power stations like the Bluetti AC200Max might not be the most compact options out there. But its size is put to good use in both the capacity, output options, and battery power. With a maximum output rating of 4800W surge power and sustained 2200W, you'll have enough juice to handle nearly any electrical needs. Plus, Bluetti packed plenty of outlets and ports for getting power out of the unit to plug in pretty much anything.
From the four AC outlets to five USB ports, including a 100W PD USB-C option, you'll be able to keep plenty of devices up and running. Like the EcoFlow Delta Pro, I loved the 30A RV plug Bluetti includes, and the wireless charging pads on top, during my review. Another thing this solar generator has in common with the Delta Pro is that it's heavy, but not quite as much, coming in at 62lbs.
The AC200Max is prepped for expansion with additional battery packs, works with a home panel to power your home safely in an electrical outage, and has an optional accessory to allow 240V power. There's also an app to help monitor and control the unit when you don't feel like using the touch screen display or can't read it because it's too bright outside. Just remember that the app only connects via Bluetooth, so if you're not close to the AC200Max, your app won't help.
When recharging the AC200Max, as any excellent power station should, it can handle power from multiple sources, including solar, wall outlet, car socket, and even an EV charging station. The wall adapter included with the power station is bulky, and only capable of 500W. This means if you're only using it to refill the unit, it will take a while. But if you combine sources, it can recharge up to 1400W.
Best budget
Reasons to buy
Reasons to avoid
If you're looking for an affordable power station, one of the first things you'll give up is battery capacity, but that's not necessarily a bad thing. When the external charging adapter is almost as large as the power station itself, it says one of two things: the charging adapter is big, or the power station is small. In this case, it's a bit of both for the Jackery Explorer 300. The solar generator is a mere 9.1 x 5.2 x 7.8 inches and weighs just over seven pounds, but part of keeping the unit so compact is to go with an external wall adapter, and they're rarely small.
While the Explorer 300 is small in size, its power output is not. The 293Wh capacity battery is capable of a 500W surge output and up to 300W sustained from the two AC outlets, three USB ports, or car socket. The power station can handle input from the wall adapter, USB-C, solar, or a combination of those options to recharge quickly.
I've loved using the Jackery Explorer 300 both for its power output and its compact size. But I do wish that its display offered a bit more. It will only show the input and output rate, and the battery percentage, with no indication of an estimated runtime. I'd also like to have seen Jackery put an LED area light on it, as this could be really helpful on this small power station.
Reasons to buy
Reasons to avoid
Anker is well-known for making some of the best power banks, and has been in the power station game for a while, too. The Anker 757 PowerHouse is a solid choice of battery for a smaller option. That being said, this is a large solar generator. But it's also a good one.
With surge output of 2400W and 1500W of sustained power from the six AC outlets, you'll have enough power for many of your electrical needs. Along with the AC outlets, there are four USB-A ports, a 100W USB-C port, a 60W USB-C port, and a car socket. Anker even put one of my favorite features of these power stations in the 757: an LED area light. But remember, you won't be able to plug a 30A RV cable directly into it.
After you've used up the power supply, Anker designed the 757 PowerHouse to get back to full quickly. Plugging into a wall outlet, you'll be able to recharge the power station at up to 1000W, getting it from 0-80% in an hour and 0-100% in an hour and a half. You can also charge it up using up to 300W max of solar. However, you won't be able to monitor anything on the unit with an app. Instead, you'll have to use the wonderful built-in display to check up on it.
I used the Anker 757 PowerHouse for a couple of months, and knowing that something this sturdy and relatively small can go with you to power anything from a window AC unit to a projector is impressive. It's not true to say that this power station is compact, with dimensions of 18.2 x 11.3 x 9.3 in and weighing in at 44lbs. However, when you consider everything it is capable of, it really isn't bad. The integrated handles are solid and make it easy to carry.
Best fast charging
Reasons to buy
Reasons to avoid
You never know when an opportunity for adventure will pop up, whether it's heading off-road with some friends or just tailgating before the game. If you've got an EcoFlow River 2 Max, you've got time to charge it up before heading out with the ability to charge the 512Wh battery from zero to 100% in around an hour at home. You can even keep it topped up with solar if it's a sunny day at up to 220W.
Despite its performance, this power station is right around 17.2 pounds with fairly boxy dimensions at 10.6 x 10.2 x 7.7 inches. For output, you get three 12W USB-A ports, a 100W USB-C port, four AC sockets, two DC 5521 barrel outlets, and a car outlet. You can charge it multiple ways, including the USB-C port, the AC port on the back, and a port for an EcoFlow solar panel on the back as well.
If you don't need a ton of capacity, you can save a bit of money by going with the smaller River 2 with a 256Wh battery, or if you need power all night and then some, the Rover 2 Pro takes the battery up to 768Wh. Regardless of which model you pick, the ability to quickly charge this power station makes it a flexible tool that can get ready for a trip as fast, or faster, than you can.
Best for solar
Reasons to buy
Reasons to avoid
Camping in the middle of nowhere is a ton of fun, with bright stars overhead and beautiful scenery. But that doesn't mean you need to leave your tech behind (unless you want to) and the Goal Zero Yeti 1000 Core power station can keep you running while you're miles from the nearest power outlet.
This 983Wh battery has multiple power output options including standard AC, two USB-A ports, two USB-C ports, a 12V car port, and a high-power output. One of the USB-C ports supports 60W PD output, which is plenty for most laptops.
More interesting than that is the input which supports up to 300W charging from solar panels. You can grab a couple of folding solar panels from Goal Zero, like the Nomad 200, which conveniently folds up to stow away when you get back on the trail.
While not everyone wants to bring a bunch of tech on a camping trip, having power available could help inspire some more of your friends or family to come along. You could also just use it to keep your drinks cold.
Power for more than just your phone
When choosing one of the best portable power stations, it's important to first consider how and where you plan to use it, and to power what devices. This will determine whether you should go compact and lightweight or heftier and more powerful. A portable power station for back-up power at home that you keep in the basement, for example, can be big, heavy, and able to power a portable refrigerator if needed. But one for camping can be smaller, lighter, and use solar power.
Durability, methods of power and charging time will also come into a play. Also consider how many and what types of ports you need.
If you want portable power to run large appliances or tools, the EcoFlow Delta Pro is an excellent choice. At 3200W, there isn't much it can't power, and when combined with its ecosystem of accessories, it can even act as a backup power source for your home.
But the Delta Pro isn't the lightest and most compact portable power station. The Jackery Explorer 300 is an affordable compact option that's easy to carry at around seven pounds. While it won't be able to run your entire home, it's great for keeping tech like a laptop, phone, or tablet running when you're out camping and the excitement of constellations has started to wane.
- Christine PersaudContributor
- Patrick FarmereCommerce Editor
