Best Motion Sensors for Samsung SmartThings Android Central 2021
There are plenty of smart devices under Samsung's SmartThings ecosystem, like connected doorbells and locks. It even has a Find feature that can help you locate a misplaced Galaxy device. With SmartThings, you can use a motion sensor to keep watch over areas of your home, allowing you to receive alerts, sound an alarm, unlock a door, or even just turn on a light. Not all Samsumg SmartThings motion sensors are created equal, however, so we've compiled a list that won't give you any headaches — like our favorite option, the Ecolink Motion Detector — so you can monitor your home no matter where you are.
- Top Pick: Ecolink Z-wave Plus Motion Detector
- OEM Option: Samsung SmartThings Motion Sensor
- Let there be light: ORRO Smart Dimmer with Motion Sensor
- Portable choice: GE Z-wave Plus Wireless Smart Sensor
- Outdoor detector: Zooz Z-wave Plus S2 Outdoor Motion Sensor
- Feature packed: Aeotec Multisensor 6
Staff pickThis great detector from Ecolink offers a five-year battery life (the best of the bunch) and flush or corner mount options. It can be set to ignore pets up to 55 pounds and is the best option of quality and price.
Samsung's own offering is also one of the cheapest on our list. With motion detection up to 15 feet and a 120-degree view range, this sensor can be set to monitor nearly any area in your home.
This sensor is more expensive than the others but that's because it combines a motion sensor with a light that can be controlled by touch, voice, or remotely using the app. It senses motion and can automatically turn the lights on or off when you enter or exit a room, or set lights to a schedule that follows sunrise and sunset.
This portable sensor from GE can be placed on a table, shelf, or anywhere you need to monitor — and then easily moved to another location. It covers a 180-degree view range and can be placed up to 150 feet away from your SmartThings hub.
A lot of the options on this list are meant for indoor use, but this versatile motion sensor is made for the great outdoors (well, at least for outside of the home). It can detect motion up to 30 feet away and can be powered by battery or via USB. Note that you'll need a hub to connect it with SmartThings.
This feature-packed option from Aeotec offers not only motion detection, but also temperature, humidity, light, UV, and vibration. Don't use six separate hardware devices when the Multisensor 6 has them all.
Sensing a smart trend
When it comes to monitoring your home for motion, you don't want to skimp on a cheap device. Any money you spend on Samsung SmartThings motion sensors will be money well spent — no matter if you're just turning on your lights or if you're keeping a watchful eye over things when you're not at home. Just add some new devices and you'll be good to go. For that, the Ecolink Z-wave Plus Motion Detector is our pick for long-lasting motion detection.
Of course, it never hurts to go with a first-party option like the Samsung SmartThings Motion Sensor, or a mobile option like the GE Z-Wave Plus Wireless Smart Sensor.
Whichever option you go with, you can feel good knowing that it will work with one of the most powerful smart home platforms in the world!
We may earn a commission for purchases using our links. Learn more.
These Galaxy S21 Plus screen protectors will keep your display looking good
The Galaxy S21 family of devices has finally launched, which means its time to find some of the best accessories. After picking up a case, you're probably going to want to go ahead and snag a screen protector to provide some added protection over what Samsung has pre-installed on the device.
The best phone deserves the best case so find the perfect S20 FE case
Samsung unveiled the Galaxy S20 FE and the device is sure to turn plenty of heads for the next few months. With stiff competition in the mid-range market, it's clear that Samsung wants to compete and the S20 FE is fantastic. If you're picking one of these awesome new devices up, make sure you pair it with a case to keep it looking awesome.
Keep your Samsung Galaxy Tab A protected with these cases
There are a lot of cases for the Galaxy Tab A that aim to keep your device protected while looking good at the same time. We have found the best options that money can buy while keeping the Tab A safe from life.
