CMF Headphone Pro is already one of the best values in audio, and it's another 32% OFF
CMF Headphone Pro review on Android Central
(Image credit: Apoorva Bhardwaj / Android Central)
What kind of headphones can you get for under $100? We've normalized spending hundreds on over-ear headphones, but CMF and Nothing make you think twice if paying that much on a new pair of cans is worth it. I tested the CMF Headphone Pro, a pair of over-ear ANC headphones that cost just $99 at full price. Despite coming from much more expensive headphones, I switched to the CMF Headphone Pro without a hitch.
They're arguably the best headphones you can get for under $100. During the final minutes of Amazon's Big Spring Sale, you can save another $32 on the already-affordable headphones. That brings the cost of a pair of CMF Headphone Pro headphones to just $67, and you'll be surprised at how much you get for that price.
CMF by Nothing Headphone Pro
Save $32
CMF by Nothing Headphone Pro: was $99 now $67 at Amazon
CMF's Headphone Pro is set of affordable ANC headphones with a comfortable, lightweight design. The headphones have plenty of tactile, responsive playback, ANC, and volume controls. You get 100-hour battery life with ANC turned off.
It's hard to believe these headphones only cost $99 at full price, but they're just $67 now.
✅ Recommended if: you want cheap ANC headphones with solid build quality; you value battery life above almost everything else; you need hi-res LDAC support and a multi-band EQ.
❌ Skip this deal if: you want the best sound quality; you need better transparency mode performance.
The design of the CMF Headphone Pro might look funky, but they're incredibly light and flexibly. They'll fit on any head shape with comfortable, and modular, ear cushions. On-headphone controls are stellar, with two buttons, a slider, and a roller. The headphones support an equalizer, but in a rare move, you can adjust EQ strength directly on the CMF Headphone Pro using the onboard slider.
These headphones also offer a USB-C port for charging and a 3.5mm headphone jack for connectivity. Sound quality is handled by 40mm drivers equipped with nickel-plated diaphragms. On the technical side, there is a 16.5 mm copper voice coil, precision bass duct, and dual-chamber design inside the CMF Headphone Pro to ensure audio sounds rich and crisp.
If you need hi-res audio, the CMF Headphone Pro uses the optional LDAC codec at up to 990kbps over Bluetooth. Battery life lasts up to 100 hours with ANC on, and half that with ANC off.
I'm an audiophile, so I see the value in paying for more expensive options like the Bose QuietComfort Ultra Gen 2 headphones. However, if you just need the basics, you won't find more for less than the CMF Headphone Pro.
TOPICS
Brady Snyder
Contributor
Brady is a former contributor for Android Central, who wrote for the site from 2023 to 2026. With a focus on news, phones, and audio, he spent years reporting and commenting on all things related to consumer technology.
Brady reviewed Apple, Google, Samsung, and Motorola phones for Android Central, and attended industry-wide events like IFA and MWC on behalf of the publication. He holds a bachelor's degree in journalism from St. John's University.
His work has been published in XDA, Android Police, Android Authority, MakeUseOf, and SoundGuys, among other sites. When he isn't experimenting with the latest tech, you can find Brady running or watching Big East basketball.
