Want an extended battery for your Droid X but not any extra bulk? Then take a look at the Seidio Innocell 1750mAh battery. With it you get nearly 17 percent more juice than you do from the battery that comes with the phone. And it has the same fit as the stock battery, so you don't need a new battery door or add any bulk to the phone. The Seidio Innocell 1750mAh Extended Battery for the Motorola Droid X is available now from the Android Central Store for $49.95. (Sponsored post)
Sponsored Post
Seidio Innocell 1750mAh Extended Battery for Motorola Droid X
This deal is expired
