The Onyx Boox Note Air 5 C has perfected the recipe for the ideal E Ink tablet
It doesn't get much better than this.
(Image credit: © Namerah Saud Fatmi / Android Central)
Android Central Verdict
The Onyx Boox Note Air 5 C is an Android 15 e-reader with a stunning 10.3-inch Kaleido 3 display. From reading and writing to Optical Character Recognition and audiobook playback, it excels at everything. The range of supported apps and files is wide, and built-in features like BOOXDrop let you freely share files or cast your screen. The latest Pen3 stylus adds a handy nib storage compartment, and the pogo pin connector for the Magnetic Keyboard Cover is a welcome addition. Aside from the extra cost of the keyboard, there's nothing else amiss.
Reasons to buy
    Same processor and RAM, but somehow performs better
    Keyboard case support added
    Android 15 with 3 years' updates guaranteed
    Navigation and gestures are smooth out of the box, unlike previous gen
    Only $30 more than Note Air 4 C
    Comes with upgraded stylus
    Compatible with Note Air 4 C cases and stylus
Reasons to avoid
    Keyboard case sold separately
    Almost identical to Note Air 4 C
Onyx Boox tablets are what Amazon's Kindle e-readers could only dream of being. Equipped with the Google Play Store, native OCR, stylus support, and a wide range of features found in full-fledged Android tablets, Boox's E Ink devices are spectacular. The Boox Note Air 4 C used to be the best E Ink tablet from Onyx Boox, and the best all-around e-paper tablet period. It was succeeded by the Note Air 5 C in October 2025, and I have been testing it for about a month now.
The Onyx Boox Note Air 5 C adds iterative upgrades to the Onyx Boox Note Air 4 C. However, the result is a polished product that performs smoother than ever before, is just as light as ever, and retains all the features that I love about Onyx Boox's Android e-paper tablets.
First, let's take a look at the technical specifications and compare what's different — or unchanged — between the Onyx Boox Note Air 5 C vs. Note Air 4 C.
Onyx Boox Note Air 5 C vs. Onyx Boox Note Air 4 C
The latest Onyx Boox Note Air 5 C costs $30 more than the last-gen Note Air 4 C, and you can buy both tablets from Amazon or Onyx Boox's website. From the 10.3-inch Kaleido 3 display to the processor and memory specs, both tablets have almost exactly the same hardware.
Design-wise, not much has changed either. Everything is in the same place, from the power button with the built-in fingerprint sensor to the USB-C port on the left-hand side of the tablet, so you can use last-gen cases on the new Note Air 5 C.
Swipe to scroll horizontally
Spec comparison
Category
Display
10.3’’ Kaleido 3, 4,096 colors, 300ppi B/W, 150ppi Color
Processor
Octa-core 2.4Ghz CPU + BSR (BOOX Super Refresh)
Octa-core 2.4 GHz CPU + BSR (BOOX Super Refresh)
Memory
6GB + 64GB, microSD slot, USB-C OTG
OS
Android 15, 3 years of updates
Android 13, 3 years of updates
Battery & charging
3,700mAh, 15W
3,700mAh, 15W
Connectivity
Wi-Fi 5, Bluetooth 5.1
Stylus
BOOX Pen3
BOOX Pen Plus
Audio
Dual speakers
Dual speakers
Extras
Pogo-pin connection for Magnetic Keyboard Cover, fingerprint sensor
Fingerprint sensor
Dimensions
225 x 192 x 5.8mm, 440g
226 × 193 × 5.8mm, 430g
Price
$529.99
$499.99
Onyx Boox has promised three years of software upgrades to both tablets. Once you update the Note Air 4 C, both tablets run the latest version of BOOX Firmware, which is Firmware V4.1. However, the Note Air 5 C runs Android 13, whereas the last-gen Boox still runs Android 13.
This means you can access nearly all the same tools on both devices, including BOOXDrop, BOOXDrop Screen Mirroring, a Smooth refresh mode thanks to BOOX Super Refresh, AI Assistant, FreeMark, Kids Mode, Split Screen, and more.
While the Note Air 4 C was a little glitchy at launch, the Note Air 5 C is incredibly smooth. Despite having the same hardware, it performs better, and even the fingerprint scanner is faster.
There are two new cases for the Boox Note Air 5 C
So why does the Onyx Boox Note Air 5 C weigh 10g more? There's a new pogo pin connector for the Magnetic Keyboard Cover. It snaps on magnetically and connects instantly, without any setup required.
The Note Air 5 C's Magnetic Keyboard Cover transforms the tablet into a portable workstation. Its Split Screen mode is optimized to work really well with the keyboard case. You can choose to switch to the Smooth refresh mode automatically when the keyboard connects for no lag or ghosting.
The Magnetic Keyboard Cover does not need to be charged, and it has a USB-C port for pass-through charging. It has a detachable magnetic flap that holds the stylus.
Unfortunately, the Keyboard Cover costs a whopping $109.99, which is too rich for a lot of people's blood. Meanwhile, the new Note Air 5 C Case costs $50.99.
Just like the Keyboard Cover, the Note Air 5 C Case also has a magnetic flap that detaches completely. This solves the issue with the Note Air 4 C Case, where the stylus would move about and go inside the folio.
The latest Boox tablet case also adds a USB-C cutout into the spine of the tablet, so you can finally charge the Note Air 5 C without having to open the folio.
Onyx Boox upgraded the stylus
The Onyx Boox Note Air 5 C comes with the latest Pen3 instead of the Pen Plus. Both styluses are battery-less EMR pens that work with the WACOM layer on top of Boox tablets.
The Pen3 is slimmer, smoother, and more streamlined, so it's more comfortable to hold, and it has a compartment to store extra nibs. Both pens also support 4,096 levels of pressure sensitivity.
Should you buy the Onyx Boox Note Air 5 C?
Onyx Boox's lineup remains the most cohesive e-reader experience in the industry, tapping into the unlimited potential of Android and the Google Play Store. The app support is phenomenal. Native OCR is amazing to the point that even if you have a PDF file that contains scanned pages of a document, you can annotate them, copy them, and recognize them offline using the Boox Notes app.
With the new Magnetic Keyboard Cover and upgraded Pen3, the Onyx Boox Note Air 5 C is a professional and educational tool of the highest caliber. It's non-distractive but not dull. Learning feels fun with the colorful Kaleido 3 E Ink panel. BOOX Firmware's intuitive plethora of tools and features facilitates productivity.
Paying an extra $30 for the Onyx Boox Note Air 5 C over the Note Air 4 C makes perfect sense. You get Android 15 instead of 13, a newer stylus, and support for a magnetic keyboard. Even if you don't buy the keyboard case right away, you always have the option to buy it later.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
