Best monitor light bars 2023
Light your computer workspace in style.
The best monitor light bars can brighten your workspace for easier reading without boosting the screen's brightness, which can be taxing on your eyes. They also come in handy during video calls by providing the proper lighting when you're in a dark setting. Light bars usually don't take up much, or any, additional space on your desk and don't cost a lot. And this is especially important if you're using an external monitor, keyboard, and mouse with a computer, like a Chromebook, and thus have minimal desk space. As you work toward enhancing your home office with items that help increase productivity and better organize the space, we've researched to find the best monitor light bars for your home workspace.
Light up your desk and make computing more comfortable with a monitor light bar
Best for customization
With three lighting modes, including warm, cool, and natural, and 10 brightness levels via a total of 84 LEDs, this light's slim and sleek design keeps crucial desk space free. Thanks to the convenient angle, there's no glare or shadows, and it's easy to set up, plugging in via USB.
Wireless remote included
The Xiaomi Mi Computer Monitor Light Bar is designed to be easy to use every day with a wireless knob to adjust brightness, color temperature, and change modes. The light bar sits on your monitor with a sturdy mount that avoids blocking any of your screen. It's also easy to adjust with no wires connecting the main light.
Directed light
The suspension and asymmetrical light design ensure this monitor light bar only lights up the keyboard and desktop. Touch control and three color temperature levels are compatible with both straight and curved screens.
Brand recognition
From the trusted folks at BenQ, this LED task lamp offers auto-dimming, hue adjustment features and complies with the standard light levels set out by the American National Standard for office lighting. It's USB-powered, and its asymmetrical design helps eliminate glare.
Relieve eye fatigue
Ideal for lengthy on-screen reading sessions, this lamp employs a suspension design that prevents glare from reflecting off the screen. It also emits a soft light that won't result in a flicker that can be annoying to your eyes, especially after poring over a 20-page report.
Versatile placement
This light bar doesn't connect directly to your monitor like others but can adhere to any surface via the stick magnet mount. So you can affix it to your desk above the computer monitor or laptop, or use it in other settings, too, like by a makeup mirror or in a closet. Bonus: It comes with a built-in 2,000mAh rechargeable battery.
Set the mood
This one is ideal for large-sized monitors and entertainment experiences like gaming or watching movies, letting you set the mood by choosing from thousands of colors and shades to use for background ambiance. Plus, it's voice-activated through Alexa, Google Assistant, and Siri with the optional Philips Hue Hub.
Price is right
You can't go wrong with the price of this monitor screen bar that still features the essentials, including adjustable color temperature and no screen glare or flicker. It also has a built-in sensor that will automatically dim based on the lighting conditions with an auto-shutdown timer.
Great for travel
Since this lamp doesn't attach directly to the monitor but instead is placed beside and positioned toward the top of the screen, it's easy to unplug and take with you between home and the office or while traveling.
What should you look for in a monitor light bar?
A monitor light bar is ideal when you tend to work in front of a computer screen for hours on end, especially if you read a lot of text. It's also good for gamers to help provide sufficient lighting that won't strain their eyes while dominating some of the best games for Stadia. When making video calls, it can also come in handy to help you get the proper lighting. The best monitor light bars should offer adjustable angles, like all of these do, so you can situate it just right to avoid reflections and screen glare. The suspension design of the Quntis E-Reading Desk Lamp that keeps the light front and center is a good example.
You also want an adjustable color temperature because the type of lighting you need to read an e-book will be much different from what you need while playing a dark, action-packed video game. The LOFTER Screen Bar Lights excel in this category with three modes: warm, cool, or natural, with 10 brightness levels provided by 84 LEDs.
Finally, if you're looking for something a bit more premium to match a clean PC setup, the Xiaomi Mi Computer Monitor Light Bar is a great choice with a sleek design, a metal body, and plenty of adjustability. The light can be adjusted to be the perfect color temperature with the wireless remote so you don't need to mess with any wires or hidden buttons to get your settings just right. It also uses USB-C so it will fit right in with other accessories for the best Chromebooks.
Get the Android Central Newsletter
Instant access to breaking news, the hottest reviews, great deals and helpful tips.
Christine Persaud has been writing about tech since long before the smartphone was even a "thing." When she isn't writing, she's working on her latest fitness program, binging a new TV series, tinkering with tech gadgets she's reviewing, or spending time with family and friends. A self-professed TV nerd, lover of red wine, and passionate home cook, she's immersed in tech in every facet of her life. Follow her at @christineTechCA.
