When you have a 7-inch tablet, you're likely not going to want a massive case. The Samsung Galaxy Tab Skin Case is a thin rubber option that will protect your tablet without making it feel like it's clad in armor.
The skin case is made of a premium silicone. It's smooth, but with grooves cut into it. Not so much for function, but for design.The rubber definitely helps you keep a better grip on the tab than if it's naked.
The case comes as a single piece. It's easiest to slip the Galaxy Tab into either the top or bottom, then stretch the opposite end around the front. And that's where we had our one real complaint -- it seemed a tad loose. Not so much that it'd slip off, but you'll need to keep an eye out for dust and dirt getting between the skin and the rear of the Tab.
Speaking of the back end, there are cutouts for the Tab's camera and flash -- as well as the dock connector, speakers, and 3.5mm headphone jack. The volume and power buttons are covered by the case but are still fully usable. So you don't lose that functionality when using this case (though some docks could possibly have issues). The skin case is thick enough to keep your Tab's screen from touching the table when left face-down.
All in all, you get a simple rubber case that will protect the back and sides your Galaxy Tab, and keep the screen from getting scratched if it's left face down. It's easy to slip on and off, and has a cool design with the grooves on the back. The Samsung Skin Case for the Galaxy Tab is available for $19.95 in the Android Central Store. More pics are after the break.
2438(forum posts)
