Cruzerlite puts a little fun into protecting your Galaxy Nexus with the Androidified A2 TPU case.
This is a minimalist skin case, but it does add some protection and it certainly adds some style.
Cruzerlite Androidified A2 TPU case
Design
The Cruzerlite gel case is made from shock absorbent and scratch resistant thermoplastic polyurethane (TPU). The case seems pretty durable and resistant to scratches.
A print of the Android logo is on the back – Cruzerlite says it is Andy the Android, I think it might actually be Lloid the Droid!
Protection
The Cruzerlite Androidified A2 TPU wraps fully around the Galaxy Nexus, protecting the back and sides.
Since it also protrudes a bit over the front of the device, it also allows you to rest your Galaxy Nexus on the screen without worrying about scratching it.
Attention to Detail
The Cruzerlite Androidified A2 TPU case seems pretty well made for an inexpensive case. The cutouts are perfect, the plastic feels pretty solid and the Droid logo on the back gives it a unique look.
The wrap up
The Cruzerlite Androidified A2 TPU case for the Samsung Galaxy Nexus is a good, inexpensive skin case for your phone. It will protect from scratches and dings and it overlaps the front just enough to protect the screen when you lay the phone on its front side.
The good
- Case has some character to it
- The case is durable
- Protects against scratches and dings
- Easy access to all ports and buttons
The bad
- Not the most "professional" looking case
The verdict
This is a good, inexpensive skin with a bit of style for your Galaxy Nexus. It gives just enough protection to keep scratches and dings from the phone. The whimsical style might make your Galaxy Nexus stand out a bit from the crowd.
Buy it now
Other cases worth looking at
- Related devices:
- Filed under:
- Tags:
4(forum posts)
