TPU – thermoplastic polyurethane – might just be the most durable material for a phone case.
Your new Samsung Galaxy S III (S3) is one of the most sophisticated and technologically advanced phones you can buy. TPU is a sophisticated material known for resisting abrasion, great low temperature performance, good transparency and elasticity and resistant to fingerprints.
These qualities make it uniquely suited for things like medical devices, flotation devices, sporting goods and cell phone cases.
The Amzer TPU case is unique combination of TPU with rubberized grips on the sides and a pop-out stand in the back for added versatility.
Amzer TPU case
Amzer takes advantage of the transparency of TPU and produced a case that is clear in parts and a solid color in other parts for a case that really does look different from other cases on the market.
Design
The Amzer TPU case is a one-piece design that covers the back and sides of the Galaxy S3. Unlike the Incipio feather case, the Amzer TPU covers the sides completely and extends enough onto the face of the phone to protect the screen if you lay it on its face.
The design is certainly distinctive on this case. My sample was clear on most of the back with solid black in sort of an “S” shape around the right side of back of the phone.
On both sides of the case, the material is rubberized for a soft and solid feel. The textured rubber on the sides makes it pretty easy to grip and hold on to.
There are cutouts for the headphone jack, microphones and charging port. The case fully covers the Power button and Volume buttons with built in protrusions to activate those functions. So, you push the buttons on the case which push those buttons on the phone which certainly protects them from breakage.
One strange thing about the design of the case is that the solid black part of my case actually cuts off the Galaxy S III logo on the back of the phone.
Lastly, Amzer includes a pop-out stand on the back of the case. We have seen this before – notably on the Seidio Active cases. This implementation is not done as well as on the Seidio cases. The stand is made of the same TPU material, but it is part of the case – not a part from the case like other kickstands. So, the back of the phone is exposed when you use the kickstand and the edges of the cutout for the stand were a little sharp and could scratch the phone under the case.
Protection
The Amzer TPU case is sturdier than the Incipio Feather case in that it covers the sided and back completely. It also feels very durable and will protect not only from scratches, but also should protect against the occasional drop of the phone.
Attention to detail
The rubberized section along the sides of the case seems like it would protect very well against hard dings and bangs. The Amzer TPU case seems well made, with the exception of the kickstand design which feels sort of cheap and is hard to open and close. The cutouts are done very well for the camera, flash and speaker and the button coverings for the Volume and Power buttons line up perfectly.
The covering over of the logo on the back shows a little lack of attention to detail.
The wrap up
The Amzer TPU case for the Galaxy S3 is a well-made and sturdy case. It should hold up well if you bang, ding or even drop your phone. I wouldn’t use the kickstand too much – that parts seems a bit ill-conceived on this case. The case does not add to much bulk and has a nice feel to it when you hold it.
The good
- Not too bulky
- Seems strong and durable
- Cutouts and button covers are done well
The bad
- Kickstand is touch to open and close and seems cheap
- Logo on back is cut in half by design of case
The verdict
The Amzer TPU case is a good alternative if you want a durable case that fully covers the back and sides of the Galaxy S3. There are a couple of design flaws, but they are more cosmetic than functional flaws.
Buy it now
Other cases worth looking at
- Related devices:
- Filed under:
- Tags:
4(forum posts)
