Best smart wall outlets 2021
By Jeramy Johnson , Olivia Lipski published
If you're converting your home into a smart home and want a more seamless and integrated solution, look into swapping out your smart plugs or your regular wall outlets with one of the best smart wall outlets. Not only can you control these smart wall outlets with your favorite voice assistant like Google Assistant, Amazon Alexa, or a home automation system, but many of them come with additional features. These include apps to create routines or USB ports so that you can charge your myriad devices. Here are the best smart wall outlets on the market right now.
TopGreener Smart Wi-Fi Wall Outlet Charger
We like TopGreener as a company because it focuses a lot of its ... energy ... on eco-friendly power management, but it also makes quality smart home products. This smart wall outlet features two USB ports and can be controlled via the app, Amazon Alexa, or Google Assistant.
iDevices Wall Outlet
This smart wall outlet from iDevices works well with Amazon's Alexa, Google's Assistant, or Apple's Siri, as well as IFTTT. But it also has a neat trick up its sleeve; you can control the top and bottom outlets independently of one another!
Kasa Smart Plub by TP-Link
Out of all of the devices on this list, chances are that Kasa/TP-Link was probably the first one you recognized. That's okay! This company is well-established in the smart home space, and this smart wall outlet is one of the top-rated ones on Amazon and other retailers.
Geeni Smart WiFi 2 Outlet in-Wall Plug
The Geeni Smart Wifi wall outlet is one of the more basic options on this list, but that's a good thing. Not only is no hub required, installation is a snap for all but the most technologically inept.
Lumary Smart Wi-Fi in-Wall Outlet
While other smart wall outlets with multiple USB ports like our top pick can be pricier, this option from Lumary comes in just under $25, so it's perfect for those watching their budget. With that low price, you get two USB ports and all of the interactive goodies associated with more expensive outlets.
Green is good
TopGreener products have a special place in our hearts because its mission is to develop products that take environmental considerations and energy management to heart. We have favorably featured several of the company's products in our reviews and smart plug roundups. It was only natural that one of its smart wall outlets graces the top of this list as well.
This smart wall outlet comes equipped with two USB-A ports and can be quickly installed. It does not require a hub to communicate with smart voice assistants like Amazon Alexa or Google Assistant, which means you can easily create automations and routines from the Alexa or Google Home app or the TopGreener app.
The best feature of this smart wall outlet is its built-in Smart Meter, which allows you to optimize energy efficiency and monitor energy usage from within the TopGreener app. What a great way to combine utility and efficiency!
This smart wall outlet from TopGreener combines the best in home automation with efficient energy monitoring and management.
Not just for Apple sheep
Android Central readers may not be as familiar with the iDevices brand or brush it off as an Apple-related product, but we can assure you that you should give this company a second look. Not only do its products work across iOS and Android, but they also work with Amazon Alexa and Google Assistant, in addition to Siri (of course).
What this brand does have in common with its Apple-inspired name is Apple-inspired pricing, but also Apple-inspired quality and features. iDevices products are generally very well-made and look great, and this smart wall outlet is no exception.
In addition to its intuitive app and voice assistant integrations, this smart outlet allows you to control the top and bottom outlets independently from one another. It has a pleasing purple light to indicate when it's in use. Oh, and it comes with an excellent two-year warranty as well.
This smart wall outlet has all of the features you'd want in a high-end smart home product, and it comes with a killer warranty.
A familiar face(plate)
Kasa by TP-Link is one of the most recognizable smart home products around. The company has been churning out quality smart plugs, lamps, and other devices for years now, and it has developed a loyal following thanks to its well-made and affordable products. It's only natural then that we included one of its smart wall outlets on this list.
Not only is this one of the most affordable options, but it's one of the most versatile. It works with Google Assistant and Amazon Alexa, and it allows you to control both plugs simultaneously or individually.
This smart wall outlet has an away mode that can turn devices on and off randomly throughout the day to appear as if someone is home. While not technically rated for outdoor use, it can be used in spaces like utility rooms and garages, with an operating temperature around 32-degrees to 104-degrees Fahrenheit and an operating humidity range of 10%-90%RH.
If you want to go with an affordable and established smart wall outlet, you can't go wrong with this Kasa by TP-Link device.
Put on a happy face
When I hear think of a genie, I think of making a wish to make a complicated problem simple, and that is kind of what this Geeni smart wall outlet does for you. It is quite literally the perfect smart wall outlet for those new to smart home automation. Allow me to explain.
For starters, this outlet does not require a smart home hub, which means that it can be controlled right away once installed. So whether you use the app or control it with your voice through Amazon Alexa or Google Assistant, you can get to using this outlet within 10 minutes!
While this device doesn't come equipped with any USB ports, it can do just about everything you'd expect from a smart device. You can set schedules, control it remotely, and create automations and routines. Oh, and best of all? The cute little smiley face on the bottom of the faceplate.
This little Geeni is here to grant your wish for a dead-simple smart wall outlet. Install in minutes and get to work!
Functionally affordable
Okay, stop me if you've heard this already. Your voice can control this smart wall outlet. This smart outlet has a great app. This smart outlet can be controlled from wherever you are.
Yeah, we know. All of the devices on this list share some or all of these features. But what makes this one from Lumary stand out? It includes two USB-A charging ports (like our top pick), but nearly half the price!
Where this smart wall outlet also stands out is that it features an in-wall tamper-resistant receptacle. This keeps it from getting overheated. There are also built-in safety shutters to prevent foreign objects from getting jammed into the outlets and short-circuiting them or shocking anyone. That makes this smart wall outlet a smart choice for families with young children.
Lumary brings all the functionality you want at a price you can afford. It also features several significant built-in safety measures.
Bottom line
When setting up a smart home, one of the best investments you can make is in smart plugs and smart wall outlets. These devices are minimally intrusive or invasive and give you the power to control all kinds of gadgets, new and old, smart, and "dumb."
Our top choice for the best smart wall outlet is the TopGreener Smart WiFi Wall Outlet Charger. Not only is it smart in the sense that you can control it remotely, but you can also monitor and manage your energy consumption. Plus, it comes with two-built in USB ports.
If you're looking for something a little fancier, I encourage you to look at the iDevices Wall Outlet. That device just looks smooth! And if safety is your number one concern, consider the Lumary Smart Wi-Fi In-Wall Outlet.
Whichever smart wall outlet you go with, you may want to consider hiring an electrician to install them for you. While this kind of work may be no problem for many of our readers, we don't want anyone taking chances when it comes to their homes and their safety.
Jeramy is proud to help *Keep Austin Weird* and loves hiking in the hill country of central Texas with a breakfast taco in each hand. When he's not writing about smart home gadgets and wearables, he's defending his relationship with his smart voice assistants to his family. You can follow him on Twitter at @jeramyutgw.
Get the best of Android Central in in your inbox, every day!
Thank you for signing up to Android Central. You will receive a verification email shortly.
There was a problem. Please refresh the page and try again.
