Best Ring products 2022
By Jeramy Johnson , Nicholas Sutrich published
Ring is one of the most well-known home security solutions providers and offers a massive variety of products to consider. That's why we've rounded up the best Ring products to help you fill out your smart home. Ring continues to make some of the best home security devices around. In recent months, the company has done a much better job of responding to and addressing the increased demand for additional data privacy controls and promises additional customer controls. With regular releases and new products coming to market all the time, our list of best Ring products can help you pick the best of the best.
Ring - Video Doorbell Pro 2 Smart WiFi Video Doorbell Wired
Ring Video Doorbell Pro 2 might require hard-wired power to keep it going, but hooking it up is well worth the effort. Incredible video quality, a super-useful head-to-toe aspect ratio, and radar-powered 3D Motion round out a sleek and attractive product.
Ring Stick Up Cam Battery HD security camera with custom privacy controls
We love the Ring Stick Up Cam because, as the name suggests, you can put it literally anywhere within Wi-Fi range and have a great home security camera. It works indoors or outdoors, can be powered by wire, battery, or solar, and can be mounted or stand alone on a flat surface.
Ring Floodlight Cam Wired Pro - 3D Motion Detection
The new Ring Floodlight Cam Wired Pro is a pretty substantial upgrade over the original product in most ways. While camera quality improvements over the original are pretty middling, the new 3D Motion feature significantly enhances motion detection accuracy and sensitivity, ensuring that this light will absolutely brighten your yard is any motion is detected.
Ring Smart Lighting – Pathlight
These Pathlights are a nice reminder that home security devices don't have to be overly aggressive or sterile in their design. These look like ordinary landscaping walkway lights but can trigger other Ring devices by linking them in the app. They can be purchased individually or in multipacks, but a bridge is required for those nifty automation features.
Ring A19 Smart LED Bulb - White
Ring now makes proper Smart LED bulbs, which connect to a Ring Bridge and can be used to automate the rest of your Ring-powered household. Like other Ring lights, these are particularly excellent choices because of their ability to connect to other Ring products and be easily automated. Just make sure you have that Ring Bridge first!
Ring Alarm 5-Piece Kit (2nd Gen) – home security system
Ring makes several different alarm kits, ranging from this five-piece offering to customizable sets with dozens of components. Not only can you control your security system with Alexa, but you can also get professional monitoring for as little as $10/month from Ring Protect.
See more than before
If someone were to stop you on the street and ask you to name a Ring product, chances are the first thing that came to mind would be some sort of video doorbell. That's the product category the company cut its teeth on, and even its name references what a doorbell does! The best Ring doorbells offer something for everyone, whether it's a fully solar-powered experience or a tiny doorbell that fits inside a door's peephole.
Our favorite Ring Video Doorbell this year is a tie between the Ring Video Doorbell Pro 2 — that's the most full-featured doorbell Ring offers — and the Ring Video Doorbell Wired, a $60 video doorbell that makes you wonder why you'd really need anything more. Unfortunately, both of these products need a hard-wired power source and should be paired with a Ring Protect Plan, as there's no local storage support at all. If you're looking for the best-of-the-best, though, it's hard to argue with the Ring Video Doorbell Pro 2.
Ring Video Doorbell Pro 2 debuts with a brand new head-to-toe video aspect ratio, radar-powered 3D motion, and has Alexa built-in so it can answer itself.
Works inside or outside
Whether you plan to move soon or just want a camera flexible enough to move around your existing home, the Ring Stick Up Cam has you covered. Not only is it easy to set up for even the least-handy person (like me), but it works equally well both indoors and outdoors. It is available as a wired or battery-powered device, but you can also power it with Ring's solar attachment or get the accessories to switch between power modes as you wish.
The Stick Up cam has a decent field-of-view for an outdoor cam at 130 degrees, but that should more than suffice if you plan on using it indoors. It records in 1080p and has two-way audio, live video, and motion notifications. This is also one of the most affordable Ring cameras you can get!
The Ring Stick Up Cam is one of the most flexible and affordable Ring devices you can get today.
Intruder illuminator
While we previously recommended the Spotlight Cam in this category, Ring's new Floodlight Cam Wired Pro makes an even better replacement. While it's not quite as portable as the Spotlight Cam since you have to wire it up to your home's power system, the results speak for themselves. The new radar-powered 3D Motion detection will turn those lights on with the slightest motion. That means you won't have to swing your arms around like a fool trying to get the light to turn on like older (dumb) floodlights.
The Floodlight Cam Wired Pro has a wider field-of-view than the Stick Up Cam (140 vs. 130 degrees), as well as two super bright LED bulbs, infrared lights, recording LEDs on the camera module, and a startlingly loud 110-decibel alarm to scare away an unwanted intruder. While it's much larger than the Spotlight Cam, that means that someone won't be mistaking it for anything other than a home security device.
Ring Floodlight Cam Wired Pro looks like a fairly ordinary floodlight from first glance, but it's so much more responsive than that old tech and can record, too.
This is the way
Typically in a list like this, the winner for "best outdoor lights" would be some kind of imposing floodlight or fancy, color-changing party light, but I decided to go a little more low-key. I like the Ring Pathlights because they look like any other high-end landscape lighting solution, and they don't have any undertones or ambitions of being a surveillance or monitoring product.
You can purchase the Pathlights individually or in multipacks from retailers like Amazon and Best Buy, so you can start small and extend your lighting as your budget and designs permit. They are battery-powered and require a Ring Bridge to be controlled by Alexa and connected with your other Ring devices.
These Pathlights will not only protect your home, but they will enhance its evening curb appeal.
The right fit
Over the years, Ring has been improving its app so that all of its products work harmoniously together in a way that most other smart home companies could only dream of. These days, Ring even makes smart bulbs that replace your existing LED bulbs. Those bulbs can then be linked to other Ring products in your home, lighting up when one of your Ring cameras or lights spots motion, or just following an easily programmable routine from within the Ring app.
At $14 a piece, they're less expensive than most other bulbs on the market, especially big-name brands like Philips Hue. Just make sure you've got a Ring Bridge before buying a bunch of bulbs. Otherwise, these won't be able to connect to anything.
Ring A19 Smart LED Bulbs
Connect your entire home seamlessly with Ring A19 bulbs, which can easily be controlled and linked to other devices from within the app.
Home safe home
As much as I love the Ring Video Doorbell 3 Plus, if I had to pick a runner-up for the best Ring product, the Ring Alarm kit just might be it. I've been eyeballing getting a version of this setup for my home for the past few months, and I might just be ready to pull the trigger.
At just around $200 for a five-piece starter kit, Ring gives you all of the functionality of a more expensive alarm system, with hooks into Amazon's Alexa smart voice assistant. You can ask Alexa to arm or disarm your system, and with Ring Protect, you can have professional monitoring for as little as $10/month. This set is perfect for smaller homes up to 1,500 square feet, but you can always purchase additional components as you need to extend the protection to fit your space.
Ring's smart security system is affordable and easy to set up. Plus, you can use Alexa to help control your system and add professional monitoring services.
Best Ring products: Bottom line
Ring has really cleaned up its image significantly from the privacy scandals that haunted it throughout 2018 and 2019. These days, Ring offers a significant number of privacy and security features that lend some real peace of mind to any home powered by its products.
Since Ring makes such a wide variety of products, the best ones will be whatever fits your needs. If you need a good video doorbell, it's hard to argue with the Ring Video Doorbell Pro 2 or Ring Video Doorbell Wired. These two products are at the opposite end of the pricing spectrum but offer the best experience in their respective classes.
If a standalone outdoor camera is more of what you're looking for, Ring Stick Up Cam can be put literally anywhere thanks to its battery-powered and waterproof nature. However, if you'd rather have some bright lights and a louder siren to scare intruders off, it's hard to argue with Ring Floodlight Cam Wired Pro. While it requires a hard-wired power source, the new 3D Motion detection is on all the time and can sense even the smallest movement thanks to its radar-powered nature.
Ring also offers a host of brilliantly designed lights that are worth mentioning. While we specifically picked out Ring A19 bulbs and Ring Pathlights in this article, don't miss out on Ring Wall Light Solar. This new 2021 product is completely solar-powered and mounts to any wall or deck, providing brilliant illumination powered by motion detection or manual control through the app. Since it's solar-powered, you'll never worry about the battery running out or wires getting in the way.
Get the best of Android Central in in your inbox, every day!
Thank you for signing up to Android Central. You will receive a verification email shortly.
There was a problem. Please refresh the page and try again.
