The best part about bringing a new smartphone into your home is all the accessories that you get to buy in celebration. Here are a few ideas of how to initially equip yourself for life with the Huawei Mate 9. And if you need some cases to accompany those new accessories, we've got you covered there, too.
Ranyi Premium Hybrid case
A great case doesn't need to be expensive or bulky. Ranyi's Premium Hybrid case for the Mate 9 is neither, but at $8.99 it's well worth the price.
Featuring a hardened carbon fiber back and plastic sides, the Ranyi case protects against drops and scratches without adding weight or thickness.
See at Amazon
AUKEY Magnetic Car Mount
car mount
It's illegal in many states to hold your smartphone while you're driving, even if you're not actively using it. Keep it out of your hands and easy to see with a magnetic car mount that slides inside your air conditioning vent. The ultra-strong magnet comes with sticky magnetic strips you can adhere to the back of your phone or inside a case.
See at Amazon
Huawei Mate 9 Desktop Charging Dock
charging dock
Keep the Mate 9 handsomly docked by your bedside or on your desk with this desktop charging dock from Encased. The stand is Type-C compatible and features a height adjustable design, in case your smartphone case is keeping the Mate 9 from properly docking. The built-in cable also enables data transfers.
See at Amazon
Arctek Type-C Car Charger
car charger
If you spend quite a bit of time in your car — commuting sure is rough — be sure to grab the Arctek USB car charger, which supports QuickCharge 3.0. It also has built in protection for overheating and overcharging, in case you need to keep your Mate 9 plugged in for the ride. This car charger is also compatible with some laptops, including the ChromeBook Pixel and Apple MacBook.
See at Amazon
Foneso Extendable Monopod
extendable tripod
Planning to shoot photos with the Mate 9's dual rear-facing cameras? Get the Foneso tripod and selfie stick combination! It's the ultimate travel accessory because it holds up your phone for selfies and stands up for group shots! The camera mount stows down to 7 inches and features a Bluetooth remote. It also offers a 1/4-inch standard screw for GoPros and other smaller cameras.
See at Amazon
We may earn a commission for purchases using our links. Learn more.
