Android Auto
Latest about Android Auto
Best USB-C cables for Android Auto 2025
By Andrew Myrick, Christine Persaud, Ted Kritsonis last updated
On the go You need a durable USB-C cable with fast data transfer so it keeps chugging along with your car.
Android Auto might let you navigate the road with smart glasses
By Nickolas Diaz published
Truly Sci-fi Recent Android Auto code may have alluded to smart glasses integration.
Google releases new Android System updates with battery life improvements
By Vishnu Sarangapurkar published
System Updates Google has released its latest system updates for Android devices, focusing on enhancing battery life, connectivity, and security.
Android Auto review: Everything you need to drive
By Ted Kritsonis last updated
Android in the car Android Auto is still the best way to use your phone while in the car, and it continues to evolve to make driving easier.
Gemini could soon replace Google Assistant in Android Auto 14.0
By Brady Snyder published
Big switch Google appears to be slowly rolling out Android Auto 14.0, and in it there are signs that a switch from Assistant to Gemini is on the way.
Android Auto's next update could bring controls for a more comfortable car ride
Gettin' Chilly Google was spotted adding code to Android Auto that teased new vehicle temperature settings.
This could be how Gemini works with Android Auto, but it needs more time
Rough around the Edges A demo video showcased what Gemini could look like on Android Auto.
Android Auto's new update causes glitches for some users
By Nandika Ravi published
Update woes A recent Android Auto update seems to have caused wireless connectivity issues for some users.
Be an expert in 5 minutes
