Let's face it, the back of the Nexus 4 is glass and it will get scratched. But it's so darn cool looking you don't want to cover it up! This is why Google announced that it would be selling a bumper case alongside the Nexus 4, but it's pretty hard to come by. Luckily case maker Poetic has stepped in here, and makes a pretty nice bumper case for the Nexus 4 at an affordable price.
The basic idea of a bumper case is to cover up the sides of the device to provide some grip and keep either the front or back panels of the phone lifted off of any surface you put the phone on. This way the edges of the case take most of the bumps and bruises instead of the glass, but you still get to keep the nice aesthetics of that glittery back plate. In this respect the Borderline case does its job. The hard plastic colored sides are accented with grippy grey rubber material, which pulls double duty adding grip for when you're using the case and grip on tables when you set it down. Speaking of colors, as of now the Borderline is available in blue, green, purple, red, yellow and black.
The case definitely adds a bit of bulk to the Nexus 4, which may push it over the edge of being too big for some people's hands. I have pretty large hands and don't really notice the extra width and thickness, but this definitely isn't a paper-thin case. Because the edges are raised up higher than the whole of the back plate, the bumper actually does make the phone a little awkward to hold. With most devices you're used to having a convex back that you can wrap your fingers around, but using a bumper on the Nexus 4 means the back is technically concave and it definitely takes some getting used to.
The Poetic Borderline bumper case is probably your best bet right now if you're looking for a good middle ground between protecting your device and showing off the striking design. And at a hair under $10 on Amazon, it's kind of a no-brainer even if you'll only occasionally use it. Stick around after the break for a quick hands-on video and photos of the case.
- Related devices:
- Filed under:
- Tags:
1219(forum posts)
