Right now Tronsmart is offering its fast-charging wireless charger with a sweet discount in the U.S., UK and Canada. Depending where you are ordering the charger from, you can save up to $6 on the recently-announced charger. It has a built-in LED that will let you know things are working, and that your phone is charging once you place it on there. It can work as both a standard charger and a fast charger, meaning you can top off that Galaxy Note 7, Galaxy S7 or other phone nice and quick.
As mentioned above, this deal is good for those in the U.S., UK and Canada.
You will need to be sure to use the correct link and coupon code to order it for your region. The deal is set to end on August 18, or when supplies run out. If you are interested, be sure to act quickly to get your order placed.
