Best Eero 6 & Eero Pro 6 Mounts 2022
By Andrew Myrick published
There's a lot to like about the new Eero 6 and Eero Pro 6 routers, and both have immediately entered contention for the best Wi-Fi 6 routers on the market. Whether you have a large home with a lot of space to cover or just an apartment with one or two rooms, the Eero 6's mesh Wi-Fi network makes sure that every inch of your home is covered. But just like with the last generation, you're probably looking for the best Eero 6 mounts to help save some space. We've got you covered with a few of the best options.
Eero Genie
The Eero Genie for the Eero 6 is easily the best option for those who want to mount either their new routers or the Eero Mesh Wi-Fi router. The router itself is secured with the help of a silicone band that wraps around while making it possible to orientate the Eero 6 in any position depending on your space constraints.
Eero Genie Pro
It only makes sense for Mount Genie to make the two best Eero 6 mounts. The company also has the Eero Genie Pro for those who grabbed the Eero Pro 6. You get the same great design, minus a little bit of flexibility as this only works with the Eero 6 Pro. But there's also a dummy prong to help keep your router secured even more.
COOLWUFAN Wall Mount Holder for eero Pro 6
Instead of relying on silicone bands to keep your Eero Pro 6, COLLWUFAN's Wall Mount Holder has guides built into the sides to simply slide your router into place. The company only offers a three-pack, which is probably the best way to go as you'll be able to mount all three of the routers in rooms across your home.
Can you use your old Eero mount with the Eero 6?
In the event that you are upgrading from your older Eero to the new Eero 6 or Eero 6 Pro, you may be wondering if you can use the same mounts. This is a question that is asked whenever a series of products is upgraded, and sometimes, the company actually keeps the same design while just upgrading the internals.
However, if you look at the Eero 6 vs. Eero Pro, you'll quickly notice that it's just not possible to use your older mounts because the Eero 6 and Eero 6 Pro both feature a slightly larger design. It's for this reason that you'll end up finding a lot of mounts for Eero routers that are not compatible with the newer version. But we do expect the number of options for Eero 6 mounts to increase the longer that the Eero 6 is available.
These are the best Eero 6 mounts
It should come as no surprise that the Mount Genie Eero Genie is the best Eero 6 mount to grab, as Mount Genie also is a fan-favorite for those with the best Eero mounts for last-generation routers. The Eero Genie is designed to fit both the new Eero 6 and the Eero Mesh routers, while being compatible with both the 15W and 24W power bricks. Plus, if you have multiple Eero routers around the home, Mount Genie offers a two-pack and three-pack of these mounts.
Those who opted to go down the route of the Eero 6 Pro instead of the standard version will want to get in on the fun with a great mount. Mount Genie is again our favorite option with the Eero Genie Pro for the Eero 6 Pro. This mount provides a low-profile, while including a "dummy ground prong" in order to keep the Eero 6 Pro supported in the wall socket. Just wrap the cable up inside the Cord Groove Organizer, place your router in the holder, and plug it into the wall.
Andrew Myrick is a Senior Editor at Android Central. He enjoys everything to do with technology, including tablets, smartphones, and everything in between. Perhaps his favorite past-time is collecting different headphones, even if they all end up in the same drawer.
Get the best of Android Central in in your inbox, every day!
Thank you for signing up to Android Central. You will receive a verification email shortly.
There was a problem. Please refresh the page and try again.
