Best Bluetooth Headphones in 2022
Side profile of Sony WH-1000XM3
Side profile of Sony WH-1000XM3 (Image credit: Daniel Bader / Android Central)
Wireless (Bluetooth) headphones have become increasingly popular over the last several years. The best wireless headphones have support for great, high-fidelity sound. That's why the Plantronics Backbeat Pro 2 are our best overall pick. They have excellent sound quality, battery life, and are comfortable for long-term use.
Best Overall: Plantronics Backbeat Pro 2
Great sound, comfort, and battery life
Reasons to buy
24-hour battery life
Sound quality
aptX and aptX LL Bluetooth audio codecs
Reasons to avoid
Micro-USB for charging
Most, if not all, modern over-ear headphones nowadays come with active noise cancellation (ANC) in the box; especially if you're looking for wireless over-ear headphones. The Plantronics Backbeat Pro 2 is our pick for the best overall pair of headphones.
First things first: the sound quality on the Backbeat Pro 2 are exceptional, and bass heads will be happy. They feature an overemphasized bass that gives the Backbeat Pro 2 an overall bass-heavy sound signature. Both the mid-range and the treble are neutral with almost zero overemphasis on either region.
In terms of Bluetooth audio codecs, the Backbeat Pro 2 perform excellently. While they don't support the AAC codec, they do have support for SBC, aptX, and aptX-LL. With aptX-LL, you'll get ultra-low latency for a Bluetooth headphone with latency somewhere between 30-40ms. In comparison, most other Bluetooth codecs have latency around 100-150ms.
Comfort-wise, the Plantronics Backbeat Pro 2 are super comfortable and shouldn't give you much trouble when it comes to comfort. This is important as they feature up to 24 hours of battery on a single charge. And when the battery is dead, you can charge the Backbeat Pro 2 over its Micro-USB port.
Upgrade pick: Sony WH-1000XM3
Sony WH-1000XM3
The ANC King, but excellent overall
Reasons to buy
Battery life
Active Noise Cancelation (ANC)
Bluetooth codec support
Sound quality
Reasons to avoid
No charging and listening at the same time
No aptX-LL
By far, the most significant feature of the XM3s is their class-leading active noise cancelling (ANC). Not only does it make travelling much easier by completely drowning out things such as planes and trains; they're excellent at blocking out higher-pitched sounds as well. The ANC you get out of the XM3 are legitimate, and it sometimes feels like you're in an empty room.
In terms of sound quality, bass heads will rejoice here. The sound quality of the XM3s lean heavily on the bass giving it a ton of thump and rumble. So much so that it can often sound overbearing and muddy. The mid-range is relatively neutral, and the treble region is recessed heavily giving the XM3 an overall warm and dark sound signature. Those who don't like a ton of bass should avoid these.
Bluetooth codec support here is excellent. The XM3s support everything from SBC, AAC, aptX, aptX-HD, and LDAC. The only codec that's missing is aptX-LL, which would get you ridiculously low latency over a Bluetooth connection. However, it's understandable that it isn't there because the XM3s have to do a ton of post-processing for the ANC.
Battery life is excellent with up to 30 hours of wireless listening time on a single charge. They even have fast-charging capability over USB-C that will get you five hours of listening in a 10-minute charge, which is impressive. One downside to the XM3 when it comes to charging is that you can't use them while wired or wireless. The XM3s will disable all functions until you unplug the USB-C cable.
Best Budget Headphones: Tribit XFree Tune
Tribit XFree Tune
They last basically forever
Reasons to buy
V-shaped, fun sound
AAC audio support
Comfortable
Battery life
Reasons to avoid
If you're looking for ridiculously long battery life, the Tribit XFree Tune are the right headphones for you. They last up to 40 hours on a single charge which will get most people through the week without needing to recharge.
In terms of sound quality, the XFree Tune perform decently well. The bass is elevated but isn't too overwhelming. The mid-range is neutral and smooth, and the treble has an emphasis, making some tracks sound overly bright. On the bright side, they do support the AAC audio codec which means you'll get higher-fidelity audio and lower latency versus only having the SBC codec.
For comfort, the XFree Tune are excellent. In our testing, we're able to wear these for hours on end without any issues. Ears stayed relatively cool, the headband wasn't pushing up against the head, and it didn't feel like the ear cups were squeezing the head at all.
Anker SoundBuds Slim
Best Budget Earbuds: Anker SoundBuds Slim
Cost-effective in-ear buds
Reasons to buy
Bluetooth 5.0
IPX7 water-resistant
Battery life
Reasons to avoid
Sound quality
The Anker SoundBuds Slim are a great set of earbuds for a stupidly low price. They feature IPX7 water resistance, which means you'll be covered in most scenarios. No, you can't just go swimming or shower with them on. But, if you drop them in a puddle by accident, or are doing some intense workout, the SoundBuds Slim should survive just fine.
Battery life wise, the SoundBuds Slim are good. They last up to 10 hours on a single charge and can be recharged using the included Micro-USB cable. Unfortunately, there's no fast charging here so to charge from 0% to full battery; you're looking at around three hours.
In terms of sound, they are decent. The low-bass, which mostly handles thump and rumble is non-existent, but it gets made up with the mid- and upper-bass boost. The mid-range has a modest boost giving leading vocals and instruments a bit of space to breathe. And the treble is a bit harsh and piercing, making these slightly tricky to listen to if you have sensitive ears.
Fortunately, that's made up in the comfort department. In our testing, we've noticed zero ear fatigue or pain when having them on for long periods. They come with various tip sizes and should cover most people's ears.
Sennheiser PXC 550
Best Over-Ear: Sennheiser PXC 550 Wireless
Sennheiser PXC 550
High-quality wireless sound
Reasons to buy
Battery life
aptX Bluetooth audio codec support
Sound quality
Reasons to avoid
It's no surprise that our best over-ear headphone selection comes from Sennheiser. The PXC 550 Wireless offer outstanding sound quality for a wireless pair of cans. The bass is neutral and even, with no real overemphasis anywhere. Bass lovers might be disappointed as there isn't much thump or rumble. The mid-range is also neutral with an overall natural response, and the treble can come off a bit unnatural and weird. The low-treble is great and even, but the mid-treble is boosted which could create a sharper and piercing sound while the upper treble is recessed quite a bit, which could make lead vocals and instruments a bit less forward.
For Bluetooth audio codecs, the PXC 550 perform well. They support SBC and aptX, which means you'll get high-quality audio and low latency if your device supports aptX. Unfortunately, they're missing AAC, which is the standard on Apple devices, and aptX-HD or aptX-LL which would bring even lower latency and higher quality audio. However, this won't matter much if you're streaming music from Apple Music or Spotify or listening to audiobooks or podcasts.
In terms of battery life, the PXC 550 are fantastic, with up to 30 hours of battery life on a single charge. Unfortunately, there's no fast charge option here. This means a full charge will take around 3 hours to complete. You'll also be getting Micro-USB here instead of the more modern USB-C for charging. However, this won't matter as much since the battery lasts quite a long time.
Skullcandy Grind
Best On-Ear: Skullcandy Grind
Skullcandy Grind
Comfortable on-ear headphones
Reasons to buy
Battery life
Sound quality
Comfortable
Reasons to avoid
The Skullcandy Grind are a great set of on-ear headphones that won't break the bank. Its design is rather minimalist with only a Skullcandy logo on the outside, above the ear cup.
Battery life is excellent as well with up to 12 hours of battery life; they should last you throughout the day without issue. Unfortunately, there's no fast charging which means charging the Grind from dead will take approximately 3 hours to come to a full charge. You'll also get Micro-USB instead of USB-C when it comes to charging.
Fortunately, the sound signature is perfect. The bass is relatively neutral and smooth with no issues there. The mid-range has a slight boost in the upper-mids, which will give the Grind a slightly brighter sound. And this extends well into the treble as well, as the entire region is boosted ever so slightly.
In terms of comfort, the Grind more than does its job. Since it's an on-ear solution, you don't have to worry about your ears getting warm. The headband extends well and doesn't get in your way either.
Bose QC30 Wireless Headphones
Best Neckbud: Bose QC30
Bose QC30
Comfy phone calls
Reasons to buy
Comfort
Call quality
Physical media controls
Reasons to avoid
No AAC/aptX Bluetooth codecs
For those looking for neck earbuds, look no further than the Bose QC30. They offer the three most important things that people have come to love with neck buds. They're comfortable around your neck and stay firmly in place so that you don't have to worry about them falling from your neck. When it comes to the earbuds themselves, they're comfortable there as well. The QC30 comes with a few different bud sizes in the box so you can choose which fits you best.
In terms of phone calls, the QC30 are excellent. In our testing, we didn't have any issues with being able to hear people on the other end, nor did they have any issues hearing us. For the most part, the person on the other end says they didn't even know we were using earbuds at all. The sound quality is also excellent. The entire bass and mid-range sound is rather neutral. The treble is a little uneven and is slightly sibilant. It's not overbearing and is controlled quite well.
When it comes to controlling your earbuds, the QC30 work tremendously. They have physical controls that mimic the classic iPod controls. Single tap them to play/pause, double-tap to skip forward, triple tap to skip back, and tap and hold for your phone's assistant.
The only real downside here is that there's no support for higher quality Bluetooth codecs such as AAC or aptX. You'll only get SBC, which is fine but you'll get a considerable amount of latency when watching videos or playing games.
Jabra Elite 65t wireless headphones
Best Truly Wireless: Jabra Elite 65t
Jabra Elite 65t
No wires, seriously
Reasons to buy
IP56 water resistance
Battery life
Fast charging capability
AAC Bluetooth audio codec support
Reasons to avoid
Micro-USB for charging case
No wireless charging case
Let's start with the charging case. The charging case gives the Elite 65t an additional 10 hours of battery life on top of the excellent 5 hours on the buds themselves. This means you'll get a total of 15 hours of listening before needing to recharge the case. It's relatively small and should fit in your pocket no problem. The only downside to the case is that it uses Micro-USB instead of USB-C for charging, and there's no wireless charging capability. The buds last up to five hours before needing to be put back in the case. But when you do put them back in the case, they'll charge ridiculously fast. You'll have up to 1.5 hours of listening from a 15-minute charge.
They also have an IP56 water and dust resistance. This means that in most scenarios, you can splash them in water and most dusty and ingress should be covered as well.
The Jabra Elite 65t have a high-quality sound for a pair of truly wireless earbuds. The bass is missing a bit of low-bass, which is expected with truly wireless earbuds. This means that you'll lose a bit of thump and rumble in your tracks, but the 65t makes up for that by having a neutral mid-bass, and an elevated upper-bass which adds a bit of boominess to the sound. The elevation in the upper-bass extends into the lower-mids, which give them a more relaxed sound. For the treble, they are great and neutral for the most part up until the upper-treble, which means you'll get a bit of sibilance which can equate to a bit of harshness and sharpness in the treble.
For Bluetooth audio codecs, the Elite 65t are good. It supports the basic SBC codec but also supports AAC, which gets you better sound quality and lower latency. It's missing aptX, aptX-HD, and aptX-LL which gets you even better sound quality and even lower latency.
Bose Noise Canceling Headphones 700s
Best Noise Canceling: Bose Noise Canceling Headphones 700s
What? I can't hear you
Reasons to buy
Battery life
AAC Bluetooth codec support
11 levels of ANC
Support for hands-free Alexa and Google Assistant
Comfortable
Reasons to avoid
Non-foldable design
Expensive
Being the successor to the Bose QC35 IIs, the Noise Canceling 700s do an outstanding job at cancelling out noise. Not only do they do the standard blocking out low-end noise, the Noise Canceling 700s make improvements in the mid-range and treble. As with most ANC headphones, they still struggle with non-consistent noises such as talking. Where Bose takes it a step further with the Noise Canceling 700s is that these now offer up to 11 different steps of ANC that can be toggled within the app. This allows you to control the amount of ANC you want on a more intricate level.
In terms of sound quality, Bose has once again made significant improvements in this area. The overall sound is rather neutral, with the bass and mid-range being very natural and balanced. The treble, compared to the QC35 IIs, have been significantly reduced to lower the sibilance and fatigue you would hear with the QC35 IIs. Unfortunately, this means that the Noise Canceling 700s also lose quite a bit of brightness and airiness that the QC35 IIs had.
The Noise Canceling 700s and the QC35 Iis share a lot in common. For example, they both still have the great 20 hours of battery life, SBC and AAC Bluetooth audio codecs support, support for hands-free Alexa and Google Assistant, and are both super comfortable for long-term use.
The only real downside of the Noise Canceling 700s is that it doesn't have a folding design. This means that when you pack them away in your bag, the carrying case is quite large as it has to accommodate the entire un-folded design of the headphone. And they're expensive, so maybe wait until they get a discount.
Beats Powerbeats Pro
Best For Sport: Beats Powerbeats Pro
Powerbeats Pro
Fantastic workout buds
Reasons to buy
Battery life
Water-resistant
Reasons to avoid
Bulky Charging Case
Lightning for charging
No Qi wireless charging for case
Pricey
The Powerbeats Pro is a no brainer if you're looking for proper workout buds. By far, they have the best battery life of any genuinely wireless earbud with up to 9 hours of use on a single charge and up to an additional 24 hours with the included charging case. They feature IPX4 water resistance, which means it should withstand a good amount of water such as sweat and light rain.
But, the best part about the Powerbeats Pro is their design. With an in-ear and hook design, it'll be near impossible for these to fall out of your ears regardless of how intense your workout is. You'll also get physical media controls that are available on both (yes, both) buds. The layouts are identical with a dedicated volume rocker on the top of the bud and a multi-purpose physical button for easy access to play/pause and skipping tracks.
In terms of sound quality, the Powerbeats Pro do reasonably well. The bass gets deeper than most wireless headphones, which gives you a good amount of thump without being overwhelming, the mid-range is nice and neutral, and the treble has a modest boost, making them slightly treble-forward. This means you'll get some sibilance in vocals and hi-hats and snares may sound a bit louder than the rest of the mix.
The only real downside to the Powerbeats Pro is that the charging case is comically large. It's clear that the case is meant to be put in a gym bag, backpack, or a purse unless it's the only thing in your jeans pocket. The case also charges via Lightning, which is better than MicroUSB but USB-C would have been preferred. Also, no wireless charging here either. Though, the buds do charge wirelessly in the charging case.
Bottom line
Bluetooth headphones will continue to evolve as more devices come out without a headphone jack. Smartphones were the first device to ditch the jack, and now tablets and even some computers are removing them entirely.
Great Bluetooth headphones should be comfortable, be out of your way, have excellent battery life, and also support higher quality Bluetooth audio codecs such as AAC or aptX. That's why we chose the Plantronics Backbeat Pro 2 as our overall pick because it encompasses all of that.
Credits — The team that worked on this guide
Author:
Peter Cao loves his headphones. He constantly cycles through and tests many headphones throughout the year. In his downtime, he likes to listen and analyze to music with said headphones.
