Lloyd
Shop Android
T-Mobile's top-of-the-line Android smartphone
 T-Mobile Samsung Vibrant
T-Mobile scored the very first Android smartphone with the G1. And now with the introduction of the Samsung Vibrant, it has one of the fastest and most powerful as well.
The Vibrant, as you know, is part of the Galaxy S line of Samsung Android smartphones, along with the Sprint Epic 4G, AT&T Captivate and Verizon Fascinate. Each remains the prototypical black slab, albeit with its own personality and customizations. And like its cousins, the Vibrant also sports one of the fastest mobile processors available, one of the best screens and some great software tweaks.
Need more prompting? After the break, we dive into the T-Mobile Vibrant and see what all the hubub's about.
(For more from the Galaxy S class, read our AT&T Captivate review)
The hardware
The Samsung Vibrant inevitably will be compared to previous versions of the iPhone, thanks to its rounded corners and plastic shell. Put that aside for a minute. What you get is a large touchscreen -- 4 inches in diagonal -- in a very slim, very slight form factor. In fact, the phone's weight probably is the first thing you'll notice when you pick it up. It almost flies out of your hand.
T-Mobile Samsung VibrantT-Mobile Samsung Vibrant
The Vibrant has a plastic shell. At left, the USB port and 3.5mm headphone jack.
The Vibrant's shell is all plastic. It may feel a tad cheap to some, but doesn't really bother us, as the build is pretty tight. The screen is ringed by a (plastic) chrome bezel. Below the screen are four capacitive buttons (meaning they respond to touch and don't actually move) arranged in the menu-home-back-search order. The back rear of the phone has a little chin to it, sort of like a reverse myTouch 3G.
The Vibrant's power button, left, and volume rocker.
There's a basic up-down volume rocker on the left-hand side of the phone. The power button has moved from its traditional place on top of the phone and instead is moved to the right-hand bezel. It takes a little getting used to if you're used to it being up top (as it is on every other smartphone we have laying around). But that's not to say it doesn't work there. In fact, it quickly becomes natural. On top of the phone you have the 3.5mm headphone jack, and the microUSB port. The port has a little sliding door that covers it, keeping out dust and lint. And unlike some methods of covering the port (we're looking at you, little rubber tabs), the door is easy to open and close by feel. Plugging in the phone is a little tough to do without looking, however.
The capacitive buttons on the Samsung Vibrant.
Much hay has been made about Samsung's new Super AMOLED touchscreens, and for good reason. Debuted at Mobile World Congress in February 2010, Super AMOLED screens promised unsurpassed color reproduction, better battery life and (most important to us), far less reflectivity outdoors. And in everyday use, that's pretty much what we've seen.
Colors pop, the blacks seem endless, and the contrast is just about as good as we've ever seen in a smartphone. And as for outdoor use, Super AMOLED pretty much has lived up to its billing.
The Samsung Vibrant has a 1500mAh battery.
The battery door takes up the entire rear of the phone and is painted in a cool carbon fiber-type scheme. It has a cutout for the camera lens and a hole for the rear speaker and is pried off from the bottom with a fingernail. Removed from the phone, the battery door is a pretty flimsy piece of plastic. But when snapped onto the phone, there's little worry that it'll pop off without warning.
You access the spring-loaded microSD card and SIM card under the battery door. You can remove the microSD card without turning off the phone, which is nice. Swapping SIMs, however, requires you to remove the battery. And speaking of the battery, it's of the 1500 mAh variety and got us through a day's use without any real problems. That includes a bunch of e-mail, web browsing, a bit of a movie and a few games.
Under the hood
The Vibrant -- as well as the other Galaxy S phones -- feature Samsung's own Cortex A8 processor, nicknamed "Hummingbird," running at 1Ghz. And on top of that you get some killer graphics processing, which has topped any benchmark tests we've run. The Vibrant has 512MB of RAM, and internal storage is split between about 1.7 gigabytes of space for store apps, and another 13GB of internal space for movies, music, photos, whatever. (And don't forget about the microSD card, which adds up to 32GB more of storage.)
Basically, know this: The Vibrant is a powerhouse. (See our benchmarks and gaming test.)
The software
Samsung Vibrant home screens
Seven home screens on the Vibrant.
And this is where things continue to shine. With the Galaxy S class of phones, Samsung unveiled its all-new Touchwiz 3.0 user interface. For those of you coming from the old Windows Mobile Touchwiz, throw out any preconceived notions of what you're getting here. Yes, it's a skin on top of Android, but it's pretty usable and well-thought out. (It is, also, a pretty colorful, which may appear a bit clownish to some.)
You have the usual homescreen layout. Seven home screens, with the middle one (or No. 4, if you please), serving as the main screen when you press the home button. You swipe left and right to move between them, and small dots at the top fo the screen are used to show which screen you're on. These dots are numbered, which is a nice touch, and you can tap a dot to move directly to that home screen.
Samsung VibrantSamsung Vibrant
The Vibrant's lock screen, left, and the home screen editor.
A nice tweak that sets the Vibrant apart from other Android phones (though it shares this trait with its Galaxy S cousins) is that you can edit entire home screens at a time. You can delete them or rearranged their order. If you only use three home screens, delete the other four. You're still limited to seven total, though.
Touchwiz docks four icons at the bottom of the screen. By default, they're the phone dialer, contacts, messaging and applications (which shows you all of your installed apps). The middle two icons (or three, on the T-Mobile Vibrant) can be swapped out for another apps, which is nice if you use something other than the stock e-mail and messaging apps. (For example, I use gmail and Google Voice.)
Pre-installed apps
Samsung Vibrant appsYes, T-Mobile has pre-installed some apps onto your Vibrant. (Helpful, ain't they?) Some are full applications, others are stub apps -- shortcuts that point you to the full download. Let's see what we've got:
  • AllShare
  • Avatar: That little James Cameron movie that a few people saw. Yes, it's the full movie.
  • GoGo: For connecting to WiFi on airplanes. You get a month free for registering.
  • Kindle: Amazon's e-reader. (stub app)
  • MobiTV
  • Audio postcard.
  • MyAccount: Access to your T-Mobile account
  • Slacker radio: Internet radio
  • The Sims 3 (stub app)
The good news: That's really not that much bloatware, in the scheme of things. And they're part of what let you buy that shiny new phone at a subsidized price, so keep that in mind. As for the quality? That's up for debate.
But really, it's Touchwiz that shines. And as far as Android skins goes, it's pretty good. The home screens aren't cluttered by the pre-installed widgets. In fact, the only widget preloaded (other than the Google search widget) is "Feeds and Updates." There's a smattering of icons, sure, but nothing you can't easily move. And you have the option to add others, including:
  • AccuWeather Clock
  • Buddies Now: A Rolodex of contacts of your choosing. Easily text or call from this widget.
  • Calendar clock: An analog clock with calendar.
  • Daily Briefing: Touchwiz's at-a-glance widget, which includes weather, news, stock and calendar info. The corresponding application provides even more info.
  • Days: Sort of a daily journal, can include photos.
  • Dual clock: Two clocks, two time zones. Great for traveling.
  • Yahoo Finance Clock: A basic analog clock with stock info of your choosing.
The keyboards
Samsung Vibrant Swype KeyboardVibrant's Samsung keyboard
Because the Vibrant doesn't have a physical keyboard, you're going to be doing all of your typing on the screen. You have three built-in keyboards from which to choose -- Swype (enabled by default), Samsung's own keyboard (it's not bad) and the stock Android keyboard.
The camera
Samsung Vibrant camera app
The Vibrant has a 5-megapixel shooter with autofocus. There's no flash, which might or might not affect you indoors. But outdoors, the camera is pretty darn good -- if you can keep your finger out of the lens. Because if its placement on the rear of the phone, that may be easier said than done. It shoots at the full 5MP by default, and you can lower the resolution down to 1.5MP if you want much smaller file sizes.
Samsung Vibrant camera testSamsung Vibrant camera test
Images open in a new window.
There are a fair number of options and settings at your disposal, including shooting and scene modes, so you can change things up for low-light, action, etc. Our favorite small detail, however, is the one-touch access to video recording. There's no having to hunt through the settings, or slide a toggle. It's nice and easy.
Fun facts: Pressing volume up or down while in the camera app zooms in and out. Pressing the power button will lock the screen. (Don't know why you'd want to do that in the camera app, but whatever.)
Samsung Vibrant Camera testSamsung Vibrant camera test
As far as the video recorder goes, it's darn good, too. It shoots in 480p by default (for smaller file sizes), and you can crank things up to the full 720p if you wish.
Samsung Vibrant video test at 720p
Other odds and ends
  • The Vibrant also is a phone, natch, and it places and receives phone calls just fine.
  • Some people have had problems with the GPS. For us, it worked just fine. It was the compass that was a little wonky. But calibrating it (by waving the phone around in the air) seemed to help.
"Avatar" on the Samsung Vibrant
Avatar on the Vibrant.
Another pro tip: The power button locks the screen while watching video.
  • Sure, it's got an accelerometer, but actually it's a "six-axis sensor," which definitely sounds cooler. Works great in gaming.
  • The speakerphone is OK. Not the best, but not the worst. It gets a bit muted when the phone's lying on its back.
  • There's TV-out capability via the 3.5mm headphone jack, if you're into that sort of thing.
Should you buy the Samsung Vibrant?
Samsung Vibrant and friends
Samsung Vibrant and friends.
In a word, yes. The Samsung Vibrant easily the best phone on T-Mobile at this point. Don't worry that it sort of looks like the iPhone. Don't worry that it "only" has Android 2.1 on it at the moment. (That will change.) Don't worry about Touchwiz. It's pretty useable. Samsung has brought a top-shelf phone to T-Mobile, and to Android. It pretty much puts the myTouch 3G line out to pasture.
As for the longevity of the Vibrant? We've got no doubt that it'll get Android 2.2 in the coming months, and no doubt that it's going to be the phone to beat for quite some time.
26 Comments
Posted by colecoyates
July 27, 2010 - 15:521 year ago
Nice review. And that last picture at the bottom is the best. Its like the mafia of phones that are taking the iphone down one step at a time.
Posted by meenalokovich
August 18, 2010 - 11:591 year ago
This phone just sucks hopefully, the second version will arrive soon. Samsung Vibrant Going Down Impression
Posted by gbhil
July 27, 2010 - 16:151 year ago
wow. great review, and very impressed with the video capture. Take note HTC.
Posted by strikeir13
July 27, 2010 - 16:411 year ago
I've asked the below question in the forums and I never got a solid answer:
Will the JIT compiler in Froyo affect graphics performance? What I'm getting at here is will there STILL be a significant difference between the Galaxy S class phones and the Droid X once they BOTH have Froyo? Any knowledgeable answer is appreciated. :)
Posted by gbhil
July 27, 2010 - 17:381 year ago
Short (and mostly correct) answer -- No.
JIT does free up processor time for other things, but it's not going to change graphics performance much at all, if any.
Posted by doz
July 27, 2010 - 16:511 year ago
You guys mentioned the tv out, I'm guessing that's a composite cable connection? What about the DLNA that's in the specs, has anyone tried that/does it work well? I've never seen someone with that system but I'll be getting a new tv soon enough and could make a point to get a compatible one.
Posted by rizoh66
July 27, 2010 - 17:551 year ago
I have and it works great. I've used it with both windows 7 and my PS3. I just hope that the docking station has an hdmi port...
Ps, I friggin love this phone. Android user since day one!
Posted by xarophti
July 27, 2010 - 16:541 year ago
I still hear stories that Samsung has crummy support for their hardware. This is the only thing that gives me pause on this phone. Anybody have experiences to share on experiences with Samsung?
Posted by pDASH
July 27, 2010 - 16:581 year ago
i'm really interested in the galaxy s line of phones, but the styling screams iphone 3GS rip-off. Plus no flash or front facing camera (no matter how useless they actually are) is mistake if they want to stay competitive. I personally love using the led flash on my droid as a flashlight (i rarely use it for pictures) and even if your not into video chatting who knows what devs will come up with in the future for ffc's. I'm shocked how cool touchwiz looks, it has a lot of compelling features! Plus 4inch screen seems like it might be the perfect happy medium... That's my 2cents!
Posted by voghan
July 27, 2010 - 17:121 year ago
I love mine.
Posted by zoltrix
July 27, 2010 - 17:191 year ago
How about a comment on whether the Captivate or Vibrant is the best overall?
Keeping the carrier out of mind, which phone do you prefer Phil?
How about the other 2 Galaxy S phones?
(i posted this in the other review too)
Posted by eyesparky
July 27, 2010 - 17:571 year ago
Excellent reviews on both the Galaxy S variant phones. Interesting from a European perspective to see how different carriers have adjusted the specifications and how that pans out over time. The thing that is a bit of a shame to see is that the included Swype keyboards do not seen to have the microphone button that is there on the Droid X version. It would really make for the ideal keyboard combination for me at the moment.
Posted by hansonator
July 27, 2010 - 18:141 year ago
The GS Vibrant that is coming to Bell in Canada has a front facing camera. I think it is like the Euro version, has the big home button in the middle. This and the iPhone 4 will have Bell's new video chat service. Can just imagine what they will charge for that.
Nice phone, I hope I win one. :-D
Posted by michaelvsshark
July 27, 2010 - 18:281 year ago
I think the point of locking the camera is so that you can launch your camera app and lock it making it available on the fly. Think being a concert and wanting to snap a quick picture or video of the band, but not have to fumble around with opening the app.
Posted by AndroidGuy25
What about the wallpapers?? I see that the wallpaper of the grass just keeps repeating versus the usual single wallpaper that sprawls across the homescreens. Does this mean you can have different wallpapers per homescreen????
Posted by garment69
July 27, 2010 - 19:301 year ago
Missing 3gb of internal memory = Avatar.
Posted by KrispyKrink
July 27, 2010 - 19:591 year ago
Uninstallable Bloat/Crapware = No Buy!
That's why I ditched buying anything pre-built by the likes of Dell, Sony, HP and went strait OS X.
And T-Mobile, a movie is a movie, not an application. It's viewable via the Android video player and you can move it from SD Card to SD Card at will or straight up delete it if you already own the DVD to import it from your own custom rip.
Posted by Jowlah
July 27, 2010 - 22:151 year ago
I actually saw the phone in person today. One of the employees at my local Best Buy got his 2 days ago. I have to say, it is a sexy phone. The colors really pop off of the screen. I guess THIS is the reason HTC has Droid Incredibles on back-order. I have a Droid Inc. and don't regret it. But it is good to see that all of these Android phones are finally saturating the market with quality product. And with FroYo just around the corner (official OTA soon), these comput..., I mean, these phones are going to have even more functionality than before. Apple had better watch out. Complacency breeds contempt.
Posted by dharma89
July 27, 2010 - 22:521 year ago
I also saw the device and I was so disappointed that Galaxy S is missing two great feature of Android - notification light and track pad/ball!!!!
i saw an article there's way to make notification light, but no presence of trackball/pad is total disappointment, and that's why i decided not to consider Galaxy S as my next Android device...
and I also surprised that none of androidcentral.com reviews mentioned this fact. as far as i remember... i think this review should mention it too. because I consider trackball/pad are essential to Android...
Posted by acjames
July 27, 2010 - 23:551 year ago
But I hate track balls and dont care for track pads. Waste of space if you ask me. Neither are on the Evo, Droid, Droid X, or the iPhone (lol)... But seriously i dont wont a track pad /ball on my phone. Something else that can cause problems....
Posted by tech42er
July 28, 2010 - 01:021 year ago
The last phone that had a trackball/trackpad was the Droid Incredible. I don't see how it's "essential to Android." The earlier phones had it, but the latest ones have mostly dropped it.
Posted by Kira
September 28, 2010 - 17:011 year ago
Seriously, how lame would that look if it had a track ball/pad on a touch screen phone? It's called touchscreen for a reason. If Samsung Vibrant is lacking the device your looking for, maybe you should consider the old school phone such as the Blackberry. They both have the device your looking for. And as for the Samsung Vibrant, it's perfectly built the way it is. Although I do have to agree with you on the notification light.
Posted by xsashagirl
July 31, 2010 - 08:431 year ago
Thank you so much for posting such an awesome review. I have been debating on whether or not I wanted to buy this phone, and I think that I have been convinced.
Posted by raisone04
August 1, 2010 - 23:101 year ago
hi i want to know does this phone come with aim? or do i have to get a data plan in order to sign on to aim
Posted by bhumphus
August 3, 2010 - 18:311 year ago
Bought the Vibrant Galaxy the day after it came out. I have used an unlocked iPhone for the past year. NO MORE! This is the best phone by far on Tmobile's market. Use the GPS fix ont he net for super fast aquisition of location, web speeds are great without difficulty. ANDROID, what can I say....
Posted by Jay_P
August 7, 2010 - 02:021 year ago
I'm probably buying the Vibrant next week. I tried it in the store for a while, it's great. The camera is so cool... I love the panoramic mode and action shots, and the quality is great. I plan on rooting it immediately, downloading WiFi Tether for Root Users, and probably installing the Droid X keyboard. I almost bought a Nexus One, but I just love the screen, camera, and hardware on the Vibrant.
Samsung has/had a mini-USB to HDMI cable for video out (so you don't need to use the headphone jack) here:
www (dot) samsung (dot) com/us/consumer/mobile/mobile-phones/mobile-phone-accessories/ECC1HU0BBEBSTD/index.idx?pagetype=acc_detail&subsubtype=data-cables-kits&returnurl=#
