Super VOOC
Mobile World Congress
Announced today at Mobile World Congress, Chinese smartphone manufacturer, Oppo, has a new battery charging technology in the works that it says can take you to 100% charge in just 15 minutes.
Sounds crazy, right?
It's called Super VOOC and is currently still in the prototyping stage, as such no new devices supporting it were announced. Equally, it doesn't seem backwards compatible to existing phones, so it's going to be exclusive to future Oppo releases.
Essentially it's the company's take on quick charging, only now taken to a pretty extreme level. The live demonstration took place during the press conference, with the prototype phone being charged entirely in the time the presentation took to deliver.
Power is delivered at a consistent 5V, which Oppo says means there's no additional heat issues to worry about, nor should it impact negatively on the life of the battery inside the phone. On a 2500mAh battery, 45% charge can be achieved in just 5 minutes.
The power adapter, cable and connector inside the phone have all been redesigned with "military grade" materials, and additionally pleasing is that it'll support both microUSB and USB-C.
Oppo says it developed the Super VOOC because current battery technology isn't advancing nearly as fast as the rest of the mobile device industry. We all use smartphones more and more, we all want longer lasting batteries. As an alternative to trying to squeeze enormous battery modules into a phone, Oppo is going down the road of charging it insanely fast, so you don't necessarily have to worry about running out.
After all, you can go grab a coffee and be fully charged before you leave.
It all sounds pretty exciting and Oppo is hoping to have an actual device hit the market with Super VOOC later this year. It's currently in the prototype stage and we'll reserve final judgment until we can actually put it through its paces ourselves. But color us intrigued.
Check out the full press release below.
Allowing users to fully charge their phones in just 15 minutes, OPPO has released its latest technology -- Super VOOC Flash Charge!
By applying a newly developed low-voltage pulse-charge algorithm, along with OPPO's customized battery, multiple technical innovations, as well as first-class hardware and software, Super VOOC Flash Charge can bring your device to a 45% charge in just five minutes of charging (for a 2500 mAh battery). This means that a full charge can be achieved in just 15 minutes! With Super VOOC Flash Charge technology, users can talk for 10 hours after just 5 minutes of charging.
The newly innovated low-voltage pulse-charge system, coupled with OPPO's customized battery, dynamically regulates the current, ensuring a safe, sustainable charging experience and preventing overheating. The Super VOOC Flash Charge adapter, cable and connector have all received a full redesign using premium and extremely reliable military-grade materials. Super VOOC Flash Charge supports Micro-USB and USB Type-C, in line with the global standard.
VOOC Flash Charge
VOOC Flash Charge was developed as a result of one of OPPO's main concerns about smartphone development. While the smartphone industry is fast-moving, the lithium-ion battery has not changed much since its creation, even though its high power consumption and endurance often leave users wanting more. Battery endurance has now become the biggest bottleneck restricting smartphone development. Meanwhile, battery capacity is constantly increasing. And with it, charging times are getting longer and longer. To offer consumers a better user experience, high-capacity batteries need to be matched with faster charging speeds. OPPO therefore zeroed in on this problem and developed VOOC as a result.
It took OPPO three years to develop the low-voltage, fast-charging technology that is VOOC Flash Charge. A totally independent undertaking, OPPO has already applied for 18 patents related to VOOC alone. Capable of charging four times faster than ordinary chargers, VOOC is the fastest and most secure smartphone charging technology.
VOOC Flash Charge was offered with OPPO's Find 7 in March 2014. With a 3000 mAh battery, the Find 7 supports two hours of talk time after just five minutes of charging with VOOC, and its power reaches 75% after 30 minutes, sufficient for a day's use. (This data is based on laboratory tests; actual charging may differ due to factors such as battery capacity and temperature, while actual call time can also be affected by the device state and real-life environment.)
With its creative solution to the issue of battery endurance, VOOC Flash Charge won praise from users and the media. In less than two years since its introduction, OPPO smartphones featuring VOOC Flash Charge saw sales exceed 17 million units in the Chinese market. VOOC Flash Charge's innovations led it to win 8 science and technology media awards internationally.
Technology Release Timeline
Version 1.0: On March 19th, 2014, when standard smartphone charging was still applying 5V1A, OPPO pioneered VOOC Flash Charge.
Version 1.1: Half a year after its release, VOOC Flash Charge speeds continued to lead the industry. OPPO then launched a VOOC Flash Charge power bank and VOOC Flash Charge car charger. Reducing the size of the original by half, VOOC Mini Power Adapter was introduced with the launch of the N3 and R5.
VOOC Flash Charge's Technical Principle
VOOC Flash Charge added an intelligent MCU chip (flash core) in the adapter in order to achieve revolutionary voltage open-loop and multi-stage, constant-current charging. VOOC Flash Charge creatively changes circuit topologies, meanwhile creates an all-side, five-level protection technique from the adapter to the interface as well as the device, securing the safety as well as the speed.
Low Voltage VOOC Flash Charge Advantages
The VOOC charging voltage is in line with the standard smartphone charging voltage of 5V. This means that the power can be directly transmitted to the battery without any voltage conversion, allowing the process to attain a charging efficiency of up to 97%. High-voltage fast charging, however, requires conversion to a lower voltage to supply power to the batter. This means a loss of energy and a lowered charging efficiency of about 85%.
Because of the difference in charging mechanism and efficiency, the temperature of a smartphone using VOOC Flash Charge remains significantly lower during the charging process than a phone using a high-voltage solution. VOOC Flash Charge-enabled devices will heat up by a maximum of only 3.3. degrees Celsius.
Because temperatures can be regulated so effectively during charging with VOOC Flash Charge, the smartphone can safely be used during the charging process. For instance, you can Flash Charge your smartphone while surfing the Internet, watching videos, or playing games. However, if you try to use your smartphone while using another fast-charging technology, the charger will revert to a standard charging speed, due to the temperature spikes caused by quick charging and screen brightening simultaneously.
