These waterproof power banks are great for emergencies and surviving through the thick of things.
When it comes to summer accessories that really stand out and make a difference, having a waterproof power bank can really save your skin in a variety of tough situations. Not only are they built to take a beating, they're great for providing battery life to your smartphone or tablet when there's not an outlet in sight. Dive in as we line up the best waterproof power banks we've found that will survive the hot and heavy this summer.
READ NOW: Best waterproof power banks
1. GJT Solar Panel 8000mAh Waterproof Power Bank
Charge up this GJT Solar Panel Power Bank before you head out for a complete backup of 8000mAh. And if you end up draining it while you're out in the wild, let the sun do the rest. The built-in lithium polymer battery charges via the monocrystalline solar panel when there are no outlets to be found, and it's completely waterproof and shockproof. On the back is an LED flashlight that's great for emergency situations in the dark, and there are 4 charging indicator lights on the front to identify exactly how much life remains. It even packs over-charge/discharge and short-circuit protection.
2. UNIFUN 10400mAh Waterproof Power Bank
Great for just about any activity, water-related or not, the UNIFUN Power Bank holds an impressive 10400mAh of backup battery life for all your favorite mobile devices while you're away from a regular power source. It features an IP66 rating and has dual USB outputs (1A and 2.1A) for simultaneous charging when battery life gets critical. You've got port plugs that cover everything up when it's not in use, and a built-in flashlight at the top that's able to keep up 6-8 days after a complete charge. Its durable construction keeps it from sliding on most surfaces and is completely waterproof and shock resistant.
3. JJF Bird Solar Panel 12000mAh Waterproof Power Bank
Here's a solar charging power bank that holds a bit more juice than the GJT option, but still packs all the same waterproof and shock-proof features. Charge up the JJF Bird Power Bank using the microUSB cable or even via the monocrystalline solar panel. There are 2 USB outputs for simultaneous charging, battery life LED's on the front for quick and easy monitoring, as well as an emergency LED flashlight up top for those hard to see situations. It comes with a carabiner clip for hooking to your backpack or pants, too.
4. EasyAcc 9000mAh Waterproof Power Bank
Rocking an IP67 protection rating, the EasyAcc Power Bank comes in handy for camping, beach days, fishing, hunting, or hiking. Its 9000mAh capacity is enough to provide a solid 2 complete charges to most mobile devices, and serves as a great companion for both day and night time use. Along with its built-in flashlight, the EasyAcc Power Bank comes with a compass, carabiner clip, carry strap, and a couple microUSB charging cables. The 2.1A output will boost your device's battery when it hits the red, whether you're miles away from civilization or lounging by the pool. There's no fretting when this tough power bank takes a dip in the drink.
5. Novobeam 3000mAh Compact Waterproof Power Bank
For those occasions when you're certain battery life isn't a serious concern, but need just a little extra security, the Novobeam Compact Power Bank is an excellent solution that's discrete, and fits just about anywhere. Since it only packs a mere 3000mAh, you're likely to only get a single charge out of it for most modern devices. It's the Novobeam's slim size and lightweight design (less than 3oz) that make it such an ideal companion for single-day hikes or fishing trips. With a 1A output, it's not out set any records in charging speeds, but it'll certainly be your savior if caught in a sticky situation.
What's your favorite rugged/waterproof power bank?
See a waterproof power bank on the list you're interested in, or do you have eyes on a different portable battery? Either way, we're interested in hearing what your go-to power bank is for those wet and extreme conditions. Drop us a line below!
Soak up some more info on summer accessories!
