The August Smart Lock Pro is down to $179.99 at Amazon today in your choice of Silver or Dark Gray. This lock normally sells for $230 and has only reached this price once before in the past (during Black Friday 2017).
You could also consider the Smart Lock Pro and August Connect bundle for $224. While that's not the lowest price we've seen, it's only $5 more. Plus, since the Connect is around $78 on its own you're saving money over buying these individually. The Connect serves as a bridge between the 3rd generation smart lock and your smart home ecosystem. The standard August Smart Lock is also down to just $99.99 today, saving you $50 off its regular cost.
August's 3rd gen smart lock gives you wide-ranging control over your front door. With August's Door Sense, you'll be able to know if your door is closed and locked from anywhere. You'll be able to control access, too. For example, you can create guest access for visitors that only lasts for a few minutes or a few weeks. You can track the door's activity 24/7, too. The lock works with most single-cylinder deadbolts, and you'll be able to keep your existing locks and keys. It will lock automatically behind you and unlock when you approach. This lock uses the Z-Wave Plus wireless protocol, so you will need a hub to connect to other systems.
See on Amazon
This post may contain affiliate links. See our disclosure policy for more details.
