Walmart is kicking off Black Friday with some great deals on electronics. Samsung's 170-watt wireless soundbar is just $99, that's $50 off, starting at 3 p.m. for Walmart+ customers. The deal will be available four hours later for other customers as long as it's still available. If you want to get in early on this and other Walmart Black Friday deals, you can sign up to Walmart+ for $12.95 per month or $98 per year. There's also a 15-day trial available. Even factoring in this cost, this is still a great deal.
This soundbar will work with just about any TV thanks to having both a Bluetooth and wired optical connection. It has plenty of power to fill even a large living room with rich sound thanks to a combined 170 watts of power. With a wider soundstage and more space to resonate, a soundbar can dramatically improve the quality of your TV experience over your TV's built-in audio. It's also great for gaming so you can get the better sound with your Black Friday Playstation 5 deals.
The included wireless subwoofer adds plenty of depth to your sound with bass notes that can help lift the rest of your audio up without compromising on detail. Whether you're listening to music or watching a movie, a subwoofer can take your audio to the next level and is essential for making the most of a soundbar setup. The subwoofer connects automatically without any connecting wires so you'll only need to find a place in the room with power access and some room on the floor.
Get it this soundbar deal early with Walmart+
Samsung 21 Soundbar Hw T415 Reco
Samsung 170W 2.1ch Soundbar with Wireless Subwoofer
Upgrade your TV with a 170-watt soundbar with a wireless subwoofer from Samsung. This soundbar can even connect wirelessly with a Bluetooth connection which means you have one less wire to hide in your entertainment system. You can still connect it with an optical cable if your TV doesn't support Bluetooth.
A wireless soundbar and subwoofer are extremely convenient for building a home theater setup with loud and clear audio and no wire mess. The wireless subwoofer also makes optimal placement easier since you don't need to worry about running a speaker wire under carpets or around door trim. Since you want to keep your subwoofer in a corner, it's not always easy to fit in but with this kit, you just need power.
Cyber Monday Deals
Check out more Cyber Monday deals:
We may earn a commission for purchases using our links. Learn more.
