Best Black Friday smart home deals 2021
Google Home Smart Home Collection
Google Home Smart Home Collection (Image credit: Nick Sutrich / Android Central)
Black Friday, the biggest shopping day of the year, is fast approaching, and it's expected that some of the most widely discounted products during this time are going to be smart home gadgets. One of the greatest things about all these sales is that it doesn't matter if you're looking for some of the best Alexa devices, awesome Google Home-related tech, or even more futuristic smart lights to build out the smart home of your dreams — it's all going to be on sale. We'll keep an eye out for the best Black Friday smart home deals as the season progresses and update this list accordingly, so be sure to check back for the latest.
Where to find the best Black Friday Smart Home deals
Smart home tech is becoming quite ubiquitous, and that means the number of retailers that offer products to add a bit of intelligence to your home operations is as well. Of course, the usual suspects like Amazon and Best Buy will be stepping up their efforts to entice you to spend your hard-earned money with them, but that doesn't mean other stores won't be pushing deals to get the sale. We'll be continuously updating this post with deals to make sure you get the be prices on the smart home gadgets you want.
Black Friday Smart Home deals: Google Home
Most Android smartphone users are quite familiar with Google Assistant, so going the route of a Nest Hub device makes sense for their smart home. In addition, because these devices use the same smart assistant that you have on your phone, there is virtually zero learning curve when using one of these hubs.
Google has done a great job of offering a variety of Google Assistant-enabled speakers for your home. If you are looking for something basic that can handle voice commands and control your smart home devices but isn't going to take up a lot of space — then a Nest Mini might be the best option for you.
However, if you want a display for touch screen controls, visual feedback and can act as a kitchen helper with recipes — the Nest Hub Max will be perfect. These are the biggest and smallest options available from Google, but there are more in between, and sure to be lots of amazing Google Assistant deals this Black Friday.
Black Friday Smart Home deals: Amazon Alexa devices
Amazon kicked off the smart speaker battles with the first Echo speaker and continues up the ante each year with more options and excellent improvements. The small but surprisingly powerful Echo Dot received a complete redesign last year and continues to be a fan-favorite every year for those both expanding or just getting started with their smart homes, and that want to do so with Alexa devices.
If you want to add a big screen Amazon smart speaker to your home, consider looking at the Echo Show 10. This device was overhauled this year — and did it ever get some new tricks. It still has a fantastic 10.1-inch display, but it has new cameras, a booming new speaker, and most impressive of all is its ability to rotate. Yup, rotate. The display will spin around the speaker when you are talking to it or on a video call so that you can always see what's on-screen.
Black Friday Smart Home deals: Smart lights
Aside from smart speakers, smart lights may be the most common and easiest way to add some intelligence to your home. Smart lights can come in many forms, from your typical bulb shape to strips of LED lights and much more. While switching to LED lights is better for the environment and can lower your energy costs, smart lights can take it a step further.
This is because when using smart lights, you can not only turn them off and on remotely but also control the brightness levels regardless if you have a physical dimmer switch or not. Smart lighting utilizes an app to manage your lights — including automation, offer tunable whites and a wide range of colors for those times you want to add some pizazz to your rooms.
When you combine the best smart lights with a smart speaker, you can go hands-off and take your smart home to the next level. Because managing your lighting without walking over to the feature-limited switch on the all is so last decade. So don't miss out on looking at the Alexa device deals or Google Home deals to add to your smart lighting.
Black Friday Smart Home deals: Smart outlets
Smart plugs are a great way to add some smart capabilities to devices that otherwise don't offer and can be controlled by an app or voice using Google Assistant or Alexa. There are some excellent wall outlets that physically wire into your home, or if you don't want to get into electrical work, you can go the route of just plugging in one of many great smart plug options out there. These can offer the same experience as wiring in an outlet, except in cases where high voltage is required for an appliance.
Making an outlet smart means that you can control any device that is plugged into it remotely. Perhaps even better, you can schedule it to power on and off at times you choose. Many plugs and outlets will also offer energy monitoring so that you can track how much electricity whatever is plugged into it is using.
A smart plug is perfect if you have a fan, electric water kettle, or anything else the plugs into the wall that isn't smart but you want it to be — make sure you get in on some of these fantastic Black Friday deals.
Black Friday Smart Home deals: Smart cameras
Home security is an area that has been seeing its products becoming more affordable in the last few years, and Black Friday is an excellent time to add some of these devices to your home. There will be a lot of products that will work great with your Google Assistant and Alexa deal pick-ups.
While the first inkling will often be to track down the best security cameras, there will be deals on other devices for helping keep your home safe. Such as sales on some excellent smart home sensors like contact and motion sensors. Whatever home security device you are adding to protect your home, there's sure to be Black Friday deals on it.
Black Friday Smart Home deals: Smart doorbells
Home security is an area that has been seeing its products becoming more affordable in the last few years, and Black Friday is an excellent time to add a device as the first line of defense to your home — a video doorbell. A great piece of news is that many of these devices will work beautifully with Google Assistant and Alexa while helping you to keep an eye on who's at the door even when you aren't home.
There's going to be some excellent sales on many of the great Ring products and other fantastic video doorbell options like the Nest Hello, to secure the entrance to your home. Regardless of which wonderful, smart video doorbell you are looking at to protect your home, there's sure to be Black Friday deals on it.
Black Friday Smart Home deals: Wi-Fi routers
Home internet speeds are more important than ever before, so we're excited that we're starting to see good Black Friday deals on Wi-Fi routers Black Friday. Whether it's a mesh or traditional router, Wi-Fi 6 or 6E, companies like Linksys, eero, TP-Link, and Asus are discounting some of their best offerings.
We'll be on the lookout for even more great deals on some of our favorite products like the Linksys AX1800, TP-Link Archer GX90, and the Netgear Nighthawk RAX120, as well as any other great bargains we come across.
Black Friday is a fantastic time to pick up smart home devices. So whether you're just getting started and need an excellent smart speaker to manage your devices, like a Nest Hub Max, or you could use a super helpful smart plug in your automated home — you'll be in luck.
While it can be time-consuming and frustrating to keep up with all the different stores and the sales, there's no need to worry because we'll do all the work for you. After all the smart home deals you could ever want are found, be sure to check out some of our other guides, from the best Black Friday Android phone deals to the best black Friday Chromebook deals.
Chris Wedel
Smart Home Writer
Chris Wedel is a fan of all things tech and gadgets. Living in rural Kansas with his wife and two young boys makes finding ways to get and stay online tricky. By utilizing his years of experience with the tech and mobile communications industries — success is assured. When not conquering connectivity challenges and testing new gadgets, he enjoys cruising a gravel road in his UTV with some good tunes.
