These AI earbuds made my meetings much more productive - here's how
Viaim RecDot earbuds review
(Image credit: Apoorva Bhardwaj / Android Central)
I attend a lot of product briefings and meetings, and that's particularly true now as we're once again heading into phone silly season. Normally, I just attend the briefing, take notes, and write up any salient points. If I'm conducting an interview — like the one about Arm's neural gaming tech — I usually record the audio and transcribe manually. That's what takes the most amount of time, and in the last six months, I used an AI-assisted solution: Viaim's RecDot earbuds.
Now, there's no shortage of AI-assisted audio-to-text transcribing services available, and you can do it on your phone as well; this is one of the things I use the most on my Pixel 10 Pro XL. Viaim is one of many brands that are positioning AI-based products to do this automatically. I used Plaud Note in the past to do something similar, but I like the idea of the Viaim RecDot better as it isn't another thing I have to carry.
The versatility of having earbuds that record calls and meetings and automatically transcribe audio is a big deal, and it made a noticeable difference in my daily use. My favorite feature is Instant Summaries, which provides insights and key takeaways from hours-long meetings; this saved me a decent chunk of time.
A pretty cool addition is FlashRecord, a feature that records conversations up to four hours locally on the buds without needing your phone. You can also record when you're not wearing the buds by pressing a button on the case. There's also an AI-assisted translation feature, and it provides real-time translations. The RecDot did a decent job with Hindi to English translations, but it didn't hold up anywhere as well with Telugu (my native language) to English. That said, the buds have the ability to translate between 78 languages, and that's a cool use case if you're traveling abroad.
The RecDot earbuds are available for $199, and while that's quite a lot of cash, you are getting decent earbuds even outside of the AI features. The buds have a standard design with a lengthy stalk, and they don't really stand out. They have a glossy coat and the shell nuzzles into the ear comfortably, and I didn't see any fatigue even with extended use. At 4.8g, each bud is light enough that you won't even notice it.
There are other niceties; the RecDot gets IP55 dust and water resistance, and sound quality from the 11mm dynamic driver is much better than I imagined; it's not going to overthrow Bose or Sony, but it's clear that Viaim paid attention to the audio tuning. You get a boosted low-end that makes listening to most modern music that much more enjoyable, and while there isn't much extension to the treble, the overall tonal characteristics are decent. You get Qi charging, Bluetooth 5.2 connectivity, and the buds connect to two devices at once.
There's pretty good noise isolation too, and the RecDot did a reasonable job tuning out ambient sounds in my immediate vicinity. Again, while they weren't as effective as my Bose QuietComfort Ultra Gen 2 earbuds, they're good enough that I wouldn't mind using the buds while working at a cafe. You don't get AptX codecs, but there's LHDC, which made a difference while using with my Find X9 Ultra and X9 Pro.
The Viaim app is what you'll be using to generate summaries and transcribe audio, and it's decent enough. I had issues where it crashed while using it on the Find X9 Ultra, but I didn't run into problems on the iPhone 17 Pro, so that's what I used predominantly with the buds. The UI itself is easy to navigate, and you get all the notes and transcribed text easily accessible.
On the whole, Viaim did a good job with the RecDot, and if you attend a lot of meetings and need an easy way to transcribe and summarize key takeaways, these earbuds are a great option.
Harish Jonnalagadda
Senior Editor - Mobile
