Spotify has brought its Running feature to Android, following its initial iOS-only release. The idea behind the feature is quite simple, yet pretty amazing. All you have to do is select your tempo and then start running. From here, Spotify will match the perfect music in time to your step to push you to keep the pace.
Spotify Running is rolling out to Android users now. Be sure to check Google Play and grab the latest update.
Source: Spotify
