Boost MAX
Large device comes with a small price
Looking to get your hands on a large screen device that doesn't carry a big ticket price tag with it? Boost Mobile has just announced the availability of its extremely affordable oversized device, the Boost MAX, which will come in off contract at only $299. Rocking a 5.7-inch display the device will have the same size screen as the extremely popular Samsung Galaxy Note 3. Out of the box this device will be running Android 4.1 Jellybean, which is a bit of a bummer, but they have included a 3200mAh battery so you should be able to make it through the day with just a single charge.
For those who will be using the Boost MAX as a media workhorse the inclusion of Dolby Digital Plus audio technology for the first time in a prepaid device is sure to make the sound quality very pleasing for you. Additionally they have included a software feature called SmartView which allows for two applications to be open on the display at the same time so you can take full advantage of all that screen real estate in the most productive way.
Priced at only $299 and partnered with Boost Mobile's shrinking $55 a month unlimited plan, this is a great choice for those looking to ditch the contract and cut back on some expenses.
Source: Boost Mobile
