Everyone wants to feel safe at home or just feel safe to leave home for a few days to visit friends and family. Setting up a home security system from Ring can keep you informed of what's going on at your home even when you're far away. Best of all, you can get a great deal on a Ring Alarm kit starting with the 8-piece kit for just $150 or 40% off. If you have a bigger house, you can also save on a kit with the 14-piece kit coming in at just $200 which is 39% off.
Starting with the smaller kit, you'll get everything you need for a 1-2 bedroom house with one base station, a keypad, four contact sensors, a motion sensor, and a range extender. The larger 14-piece kit comes with a base station, two keypads, eight contact sensors, two motion sensors, and a range extender. You can also choose from a number of bundles with Ring Doorbell cameras and the Echo Show so you can see what's going on in your home.
This Ring system works great with Alexa so if you're taking advantage of best Black Friday smart home deals with Alexa, all of your devices can work together. As you walk out the door, there's no need to mess with a remote or use the keypad, you just need to tell Alexa to enable the alarm. There are a lot of accessories to customize your Ring system for your home and needs. And with 24/7 monitoring and easy access, these Ring Alarm kits are a great way to improve your home's security.
Ring Alarm 2nd Gen kits are up to 45% off at Amazon
Ring Alarm Kit 8 Piece
Ring Alarm 8-piece kit (2nd gen) | 40% off
This Ring Alarm kit comes with everything you need to get started on a 1-2 bedroom house. The kit comes with one base station, a keypad, four contact sensors, a motion sensor, and a range extender.
Ring Alarm Video Doorbell Echo Show 14 Piece
Ring Alarm 8-piece (2nd gen) with Ring Doorbell and Echo Show 5 | 45% off
One of Ring's most famous products, the video doorbell, can be bundled in for an even greater discount. You get everything that comes with the 8-piece kit as well as a doorbell to record what's going on at the door as well as an Echo Show to see it from inside.
Ring Alarm 14 Piece Kit
Ring Alarm 14-piece kit (2nd gen) | 39% off
If you have a bigger home, you've got a lot more doors and windows to secure. This 14-piece kit is designed to serve a 2-4 bedroom house with a base station, two keypads, eight contact sensors, two motion sensors, and a range extender.
The package you pick comes down to how many doors and areas you want to monitor. Luckily, you don't have to commit all at once. You can start small and add in more sensors and accessories as desired. Since it's all DIY, you don't need to call a professional to get it set up every time you want to upgrade your system. These are great starter kits with everything you need to get your system up and running but as every house is a bit unique, you still might need a bit of customization like picking the right video doorbell.
We may earn a commission for purchases using our links. Learn more.
