Whether you're trying to buckle down and focus in an open office, or catch a nap on an airplane, noise-cancelling headphones are one of the best ways to drown out the noise around you. Headphones with active noise cancellation work better than versions with passive noise cancellation, meaning they're typically much more expensive. However, today you can get the Cowin E7 Pro Active Noise-Cancelling Headphones for $67.99 from Amazon. That's a $22 discount and the best deal we've seen for the Black colorway since Prime Day back in July. These headphones actually come in a few different colors, some of which are also discounted, though none are as inexpensive as the Black pair. They all ship for free as well. Note that this offer is only valid for a limited time, meaning you should move quickly if you're interested.
Save big on these VPN services ahead of Black Friday
Stream Post Malone
Cowin E7 Pro noise-cancelling Bluetooth headphones
This is the best deal we've seen for the Black color since Prime Day. These well-rated headphones have rich sound, a 30-hour battery life, and active noise cancellation. Other colors are slightly discounted as well.
$67.99 $89.99 $22 off
With 4.3 out of 5 stars based on an average of nearly 5,000 customer reviews, these headphones are some of the highest-rated you can buy in their price range. They feature advanced active noise cancellation, which means they physically work to dampen the noise around you. That function works in both wired and wireless mode.
With proprietary 45mm drivers, you'll get deep, accurate bass and crisp highs. That means your music will sound great even without the noise cancellation. The ear cushions are soft and durable, and they swivel for extra comfort too. The E7 Pro also have a built-in microphone that allows you to take hands-free calls. When you're done listening, you can fold the headphones down and store them in the included carrying case for easy travel. You'll also get a micro-USB charging cable and a 3.5mm auxiliary cable for listening in wired mode.
The 30-hour battery life should last you through the work week, and the headphones charge up pretty quickly as well. Your purchase is backed by an 18-month warranty.
We may earn a commission for purchases using our links. Learn more.
