The Acer Predator XB271HU 27-inch WQHD G-Sync monitor is down to $419.99 on Amazon for Prime Day. This is a new low price for this screen, which usually sells for around $500 and sometimes as high as $560. The previous best deal we've seen for this monitor was a drop to $450 back in January.
G-Sync
This is the lowest price we've ever seen by $30, and the monitor has a lot of good going for it.
$419.99 $500.00 $80 off
The monitor has a 2560 x 1440 pixel resolution, a refresh rate of 144 Hz, and a response time of 1 ms. It is compatible with Nvidia G-Sync technology, which helps you reduce screen tearing in games. The refresh rate can even be overclocked to 165 Hz using DisplayPort. Connectivity options include the previously mentioned DisplayPort and HDMI. It uses a TN panel and has VESA mounting on the back.
We may earn a commission for purchases using our links. Learn more.
