The Acer EI491CR 49-inch curved 3840 x 1080 FreeSync 2 144Hz VA monitor is down to $699 on Amazon. The screen normally goes for around $900. It initially only dropped to $800, but the Prime Day discounts don't stop and it has now dropped to an all-time low.
Wide
You'll feel like you're on the bridge of a starship. The curve basically surrounds you and envelops you as you play your favorite games.
$699.00 $900.00 $201 off
The 49-inch display has an 1800R curve and a resolution of 3840 x 1080. It also uses AMD Radeon FreeSync 2 technology that helps reduce screen tearing while playing high octane video games. The refresh rate is 144Hz and the response time is 4ms. You can wall mount this, too, with the VESA standard on the back. Connectivity options include one DisplayPort, one HDMI 2.0 port, and two HDMI 1.4 ports. It even has built-in speakers.
We may earn a commission for purchases using our links. Learn more.
